I am learning op amps and am confused about one concept. The output current of the op amp. Assuming ideal op amps the input side would have infinite resistance and therefor 0 amps. However the output side would have 0 resistance.
Using V=IR V/R = I
if R = 0 then its undefined...
Does it have something to do with R2 in the drawing? The resistor values are just arbitrary values.
