What do you think about converting pc power supply to bench power supply? Is it ok for amateur use?
Edit: I thought it has some current limiting mechanism, but I see it doesn't. It's big problem in my case. I only need few hundreds miliamps on every voltage level. Can this problem be solved by some external current limiting circuit?
