-1
Faulty Circuit
Okay so I am new to Proteus Simulation software.
I made the above displayed circuit but cant seem to get any errors. If I make all the right connection the LED works but it shouldn't as LED is 20mA and I am passing current of more than 100 Amp..
Any idea why Proteus does not show any breakdowns ???
  • \$\begingroup\$ Not familiar with Proteus, but all the Spice simulators I used so far did not include any self-heating, breakdown or overstress simulation. Even saturation effects in inductors are rarely found. That's all part of the engineers work (to know the limits of the parts). \$\endgroup\$ – Arsenal Nov 20 '15 at 8:03
SPICE simulators require that you have a ground port inserted into every circuit for reference, usually connected to the negative side of the battery. It also looks like you've installed both a current source and a battery array? I'm not sure what you expected there. Also one end of the batteries isn't connected to anything.
