Got a temperature regulated solder iron, always had the temp set to 350C. Used the wet sponge after every solder job to clean the tip. Used a 60/40 rosin core 0.6mm solder. After week of use, when turning it on again I noticed the stock tip only had few areas where the solder would stick to. The areas were visible, they had dull metallic look, the rest areas were darker. Tried cleaning with wet sponge, made no difference. Finally had to use very fine sandpaper. After that no part of the tip was usable anymore. But the surface was metallic, not copper color so I don't think I sanded away all the tip cover. Is there any explanation for this?
Replaced the tip with a new one which came with the iron. Solder sticks to it well, but I don't know how long this one will last. Here are pictures of how a 60/40 solder looks on it (wanted to tin the tip). Very odd coloring. Does this give any explanation?
Not a professional, so didn't get an expensive quality solder station, but this one wasn't cheap either and had a iron holder, replaceable tips and temperature knob. The iron itself seems to work fine.
  • \$\begingroup\$ How were you trying to tin the tip? What tinner were you using? \$\endgroup\$ Nov 20, 2015 at 11:02
  • \$\begingroup\$ I meant to say I applied some solder to the tip before turning it off. \$\endgroup\$
    – Leo Ervin
    Nov 20, 2015 at 11:18
    \$\begingroup\$ Some tip rejuvenators use "salammoniac" if I remember correctly. Goog probably knows. These can bring dead tips back from the dead. | With good solder DO NIT wipe AFTER use, instead wipe just before use - solder & flux on tip increases life. | \$\endgroup\$
    – Russell McMahon
    Nov 20, 2015 at 13:24
There are definite quality differences between tips from different vendors, the base material used may differ (steel, iron, copper, silver) - Though I don't generally support silver as it gives near to no benefits over a well coated copper one, I have recently posted an answer on that here. But there is also difference in coating quality and even type and some last longer than others.
What you should never do with any coated tip (99% of them) is clean them with hard abrasives. Very cheap tips might not even like those steel mesh sponges, but if your tip is that cheap...
Which brings me to another piece of advise: Try if you like a steel mesh sponge, many outlets have them at a buck or two, they need no wetting and if you can get the movement right easily they clean well enough, but at 350degrees offer a much lower chance of cracking of the coating. But those are not for everyone and in many cases a lightly wet sponge (not soaking! Very easy to crack the coating when it's soaked) cleans better.
To restore a coating there are things like "Tip Activator" that you can use. A small $8 can from cooper tools / weller can last you dozens of uses and for most people you only need it once per year, or even longer for each tip you use regularly. It basically cleans a little and leaves a bit of coating layer extra behind. But never use it on a new tip of well coated quality. As with anything, a cheap home solution to add coating or such is always less good than a good factory coating.
You may be able to restore your damaged tip to sort of working order with tip-activator as well, I have used it to get horrible uncoated stainless steel tips to usable for a month or two, so it's worth a try.
Usually tip-activator works best when you put in a tip at 150 ~ 200 degree C, but the datasheet or booklet that comes with it will say how to use it.
It looks like you got crud on the tip as apposed to the tip coating wearing off. First, use a lower temperature unless you are doing desoldering. I use 600°F (315°C) for normal soldering, then 650° (343°C) or 700° (371°C) for special circumstances. Even then, turn the iron back down to 600° when done so that it's not sitting there for a long time in the holder so hot.
Eventually, even with good care, a blackish crud will build up on the tip in patches. It may look like the tip coating is worn off, but that's not what's happening. A good tip cleaner will take care of it. In a pinch, you can gently scrape the crud off the tip with a screw driver or something. Gentle is important to not hurt the tip coating. Then tin the tip immediately afterwards with fresh solder, and it should be OK again for a while.
Never sand a tip or use hard abrasives on it. That will damage or remove the tip coating, after which the tip is junk.
  • \$\begingroup\$ The photos are me applying solder on the tip, not the issue I described I have on an older tip. \$\endgroup\$
    – Leo Ervin
    Nov 20, 2015 at 12:30
