I am having a mind blowing misbehaviour in my PIC16F1825. Basically I am using pin 3 (RA4) to toggle a LED using an Interrupt-on-Change. Problem is, although it toggles the led whenever I press the button (which is externally pulled up), after a second, the LED toggles again, which means that the interrupt routine was called again, and it shouldn't, even though I clear the interrput flag.
Here's the code (only function IOconfig_portA() and toggleLed() matter for the problem at hand:
#include <stdio.h>
#include <stdlib.h>
#include <PIC16F1825.h>
char temp=0;
void interrupt toggleLed() {
INTCONbits.GIE = 0;
if(INTCONbits.IOCIF == 1) {
temp = PORTA;
INTCONbits.IOCIF = 0;
LATC3 = ~LATC3;
for (int i = 0; i < 100000; i++);
INTCONbits.GIE = 1;
void CLOCKconfig() {
OSCCON = 0x6A; //Sets the internal oscillator fosc = 4 MHz
OSCSTAT = 0x00;
OSCTUNE = 0x00;
void IOconfig_portA() {
ANSELA = 0x00; // All ports set as DIGITAL
TRISAbits.TRISA4 = 1; // Set as input
//OPTION_REG &= 0x7F; // Clear bit 7, to enable the weak pull-up
//WPUA |= (1<<2); // Enable the WPU for RA2
CM1CON0 = 0x00;
CM1CON1 = 0x00;
IOCANbits.IOCAN4 = 1; // Generate Interrupt on Negedge
IOCAP = 0x00; // Disable Interrupt on Posedge
INTCON = 0x88; // Enable GIE and IoC interrupts
int main(int argc, char** argv) {
TRISC = 0;
CLOCKconfig();
ANSELC &= 0x00; // All bits on port C are set to Digital I/O's
TRISC &= 0x00; // All bits on Port C are set to Outputs
APFCON0 |= (1<<5); // Don't use special features on Pin RC3
APFCON1 |= (1<<2); // Don't use special features on Pin RC3
IOconfig_portA();
LATC |= (1<<3);
while(1) {
return (EXIT_SUCCESS);
Thanks in advance!
that has no place in an ISR! First rule of interrupts is the handlers should finish as quickly as possible and not block for long periods of time. Also theINTCONbits.GIE = ...
lines are unnecessary (it is done internally by the PIC when entering and exiting the ISR). \$\endgroup\$ – Tom Carpenter Nov 22 '15 at 16:48
