8
I have a 3V3 rail and want to run an LED with a Vf=3.1V at 10mA with a constant current source. I'm used to circuits like the one below but the problem is that I only have 200mV of overhead and discrete circuits I am familiar with count on the 0.7V Vbe, which would brown out the LED.
Can anyone provide a constant current circuit using cheap discrete parts that can provide 10mA with less than 200mV of overhead? I am familiar with specific LED drivers or circuits that use op amps but they seem like engineering overkill to turn on an LED.
    \$\begingroup\$ did you mean 200mV? whats the problem of using a single resistor? \$\endgroup\$
    – Wesley Lee
    Commented Nov 23, 2015 at 17:50
    \$\begingroup\$ His 3.3v is regulated but the LED's 3.1v can vary. Any change in the forward voltage compared to 200mv is a big change in the required resistor value. (This would make a good question on its own). \$\endgroup\$
    – gbarry
    Commented Nov 23, 2015 at 18:12
    \$\begingroup\$ Corrected to 200mV. A single resistor will not be constant current. \$\endgroup\$
    – EasyOhm
5 Answers 5
9
You could use something like the below, which requires less than 60mV of headroom. Sense voltage is only 50mV so the offset voltage of the op-amp will tend to greatly affect the current. The LED could be controlled by connecting R3 to a port pin.
(R4 and C1 may not be necessary- it may be possible to omit C1 and short R4 but that would have to be determined- that phase margin is enough for good stability)
Note that if your supply is nominal 3.3V and your LED nominal 3.1V Vf you still may not have enough headroom if the LED happens to be on the high side and your 3.3 turns out to be on the low side.
I came up with this circuit in trying to come up with a cheap LED flashlight for poorer people. The inexpensive flashlights tend to just use a resistor only, and would waste too much power (money) for those who only make a dollar or two a week. I finally settled on 2.6mA as the minimum usable light level, which I've been using for a few years. I've changed the batteries once, and they seem to last forever. I do believe that the overhead of this circuit is about 200mV, which is what you wanted. Replace R9 with a trimpot or a potentiometer to make it adjustable, or to find the actual value of the resistor for your particular LED. Remains fairly stable in the temperature range that I expect a flashlight to operate in, but it might not work well in Alaska or Death Valley, and need the trim-pot instead of a resistor if your product goes world-wide.
A Linear Regulated Discrete Constant Current LED Driver delivering about 10mA:
Discrete Constant Current LED Driver -- a Linear Regulator
    \$\begingroup\$ I like it! I wonder how much of an issue per-specimen hFE variation in PNP4 is... Do you need to calibrate every individual circuit? Also, have you ever observed stability problems with your circuit? (I've seen stability issues with the simple 2T2R variant, but that might have been caused by long wires) \$\endgroup\$
    – marcelm
    Commented Sep 10, 2020 at 19:16
    \$\begingroup\$ It looks like you are dangle-biasing PNP4, relying on its exact open-circuit beta to set the LED current. This is not a stable circuit. A transistor's beta varies with collector current, base current, collector-emitter voltage, temperature, age, manufacturer, manufacturing lot, and just about everything else except the phase of the moon. \$\endgroup\$
    – AnalogKid
    Commented Jan 12 at 22:35
  • \$\begingroup\$ @AnalogKid -- All true, but it doesn't matter when it's a flashlight having a potentiometer or digital potentiometer at R9. If the power source is two $12 450-Farad 3V supercapacitors in series (for 6V), this circuit keeps a very steady brightness for a few hours until the power is gone. Make it as dim as you can, but still bright enough to read, say 3mA, and it should last several days. \$\endgroup\$ Commented Jan 14 at 21:05
This should solve your problems. It's a constant-current charge-pump LED driver: Maxim MAX1910/MAX1912 datasheet
It will accept a wide voltage range and you can set your desired LED current. This doesn't have compromises others have provided and mitigates the following:
  • Spehro - eliminates the op-amp offset dependency
  • Microservices - circuit is no more stable than a single resistor.
  • Nick - doesn't allow adjustable current.
    \$\begingroup\$ Link-only answers aren't received well on the site. There should be enough information in your answer (or question) that it can stand on its own. \$\endgroup\$
    – Transistor
    Commented Jan 12 at 23:44
  • \$\begingroup\$ @Transistor Understood. I figured all the details that are needed are in the datasheet. TBH, I would be happy if someone suggested an IC for a design that I was unaware existed. \$\endgroup\$
    – MOSFET
    Commented Jan 12 at 23:51
  • \$\begingroup\$ It is nice that this solution is nonlinear (and probably reasonably-priced), but contrary to its "High Efficiency" on-the-face claim, average efficiency is only 75%, still better than linear, but I would not accept its "High Efficiency" claim. \$\endgroup\$ Commented Jun 28 at 1:47
I've shown this circuit in a couple of places I think, and used it a number of times -- mind, mostly for personal projects[1]. Looks like a good fit here, so, without further ado:
Source: my website, https://www.seventransistorlabs.com/Images/Low_Sat_CCS.png
Compared to the normal ring-of-two CCS as in the OP, we have the load resistor R_L, the main pass transistor Q1, and current-sense R1. The change is everything else.
Realize we can consider the common-emitter BJT, as an error amp with built-in VBE input offset, or as a differential amplifier against same, and this more or less describes operation of the ring-of-two circuit.
We can replicate the same function, using a differential amplifier circuit. This allows a lower VREF, higher precision (overall loop gain), and removes the VBE temperature dependency (at least to first order, or as an intrinsic design element).
Note that VREF isn't shown. It can be a resistor divider if VCC is reasonably stable, or when a proportional control is desired; it can be a VBE, divided down as needed, if the tempco is acceptable; or a zener, TL431, or any other kind of voltage reference, will give excellent stability. It can even be inputted from a potentiometer or DAC for variable control.
As shown, 100mV VREF is quite feasible, a worthwhile improvement over the ~700mV original. I wouldn't recommend using this below 50mV or so, where device matching (including thermal), and offset and gain, become much more significant issues. The VBE error between random parts can be 20mV or more; for same-lot (often same-wafer) parts, the average is closer to 5-10mV, not fantastic but acceptable for most discrete analog purposes.
For very low voltages, I would strongly suggest a proper op-amp IC instead; perhaps a precision or auto-zero type, and using Kelvin connections to avoid error in the shunt resistor.
Matched-die parts are available, for example BCM857DS, a dual intended for current mirror or diff-pair application. Note these do not track thermally because they are not monolithic (same die) pairs. They are independent dies connected only by the plastic package. For best results, minimize differential heating by using low operating voltage and current, and similar conditions in both transistors.
C1 is an important detail: with multiple stages in the feedback loop, compensation is a concern, and enough phase shift may be present that the circuit oscillates. C1, maybe with some series resistance, is used to degenerate the gain of Q4 at high frequencies, reducing loop gain and increasing phase margin. Values can be tested by measuring output current under a step-change input condition.
Finally, D1 sets a limit to GATE voltage, a few volts above VGS(th). More than VGS(on) won't be useful, and pushing near VGS(max) risks device failure. (Incidentally, note that D1 provides an AC ground-return path to Q1 gate, which might turn it into a Colpitts oscillator; a ferrite bead in series with the gate pin or D1 may be desirable.)
D1 can be omitted if VCC is under VGS(max).
Analog Design
Analog circuits are fascinating, and so rarely a topic of study these days, that I think it's worth further discussing this circuit in more detail.
The diff pair can only be NPN or PNP[2]. NPNs would require a negative supply for the tail current (about -0.6V), so, aside from some very obscure tricks[3], we'd need an additional supply, which is probably a huge pain. So, PNP it must be.
With TAIL being about VBE+100mV above ground, we can drive the collector(s) into a load of VBE (without the 100mV), and avoid saturation of the diff pair.
The diff pair load must be a VBE, give or take, because we need another amplifier to level-shift up to VGS, and a CE amplifier fits the bill.
Incidentally, we could run the CE amplifier at lower current, or use a wider-area junction, to further decrease its VBE in relation to the diff pair's. R2 and R4, as shown, aren't in such a ratio that would give this trade-off; it would be more like R4 = 47k and R2 = 4.7k to do that. But such a trick isn't important for VREF in the 100s mV range.
Note that the change in VBE with IC is quite meager: ΔVBE goes as 60mV per decade of IC ratio, so, even if R4 = 100k and R2 = 4.7k, it's only a 60mV overhead, hardly important. But, if we needed to operate all the way down to zero VREF, that would indeed be enough to get us there. Again, assuming matching is solved, which means a monolithic matched pair -- but that puts us right back into boutique-land, so, it's again not important here.
We could also use a folded cascode, which doesn't afford current gain (a second stage might still be required), but it avoids the VBE headroom concern at the diff pair. This is definitely not important here, but is a staple of low-voltage analog circuitry, monolithic RF amps, etc.
Alternately, we could use the VBEs-at-ratio-current trick to give a small but stable offset voltage; this is small indeed (again, mid-10s mV), so not really useful for VREF here, but with some amplification, it becomes the basis of what's called a bandgap voltage reference. Again, for all these reasons, not really something you want to do with discrete components, but it's a keystone of IC design!
The loop gain might also be noteworthy here; if R4 were replaced by a CCS (a PNP current mirror, perhaps), the loop voltage gain can be quite high indeed (thousands, limited by Q4 and CCS Early effect). However as shown, since Q1 gate current is minuscule, R4 dominates. Again, hardly important for LED drive (accuracy of say 10% is already more than required), but in a higher precision application, or for signal purposes (say you want to build your own discrete op-amp for S&Gs), the higher gain will be desirable.
Note that, even with a CCS, loop gain is limited at AC by Q1's gate capacitance. Which is further compounded by Miller effect. Which, even further, means R_L's exact (AC) impedance is a term in loop stability -- when using such a circuit as DC load for example, an R+C from DRN to ground can be desirable (ballpark values for an IRFZ34N might be 10nF + 10Ω, but depend on circuit characteristics). This is probably not required for an LED load, but perhaps if the LEDs are quite distant from this regulator circuit, the reactance of those cables could become an issue.
[1] I probably wouldn't bother with / recommend this approach for commercial use, where ICs are available with comparable or better performance in fewer parts. Let alone where altogether different solutions are possible, that a stand-alone CCS cannot possibly solve itself: for example, an SMPS with CC/CV output, directly delivers power into a variable load, at high efficiency, without a dropper circuit at all.
There is some space for compromise, where a dropper handles short-term fluctuations, and a switching control circuit handles it long-term; many mid-market LED products are designed this way, with a PFC (power factor correction) front-end to draw sinusoidal mains current, which necessarily outputs some (100/120Hz) voltage ripple, which is taken up by the dropper stage. (The PFC stage also can't change very quickly, since its control has to average over multiple mains cycles.) Higher efficiency requires a 2nd switching stage, and thus increased cost.
[2] I mean, it could be MOS, but discrete matched MOSFETs aren't available other than boutique. It'll be a cold day somewhere when boutiques are better than BJTs for driving LEDs, so, I'll stick with BJTs here.
Also, there's such a thing as a "complementary diff pair", but it has two VBEs instead of ~none, so, isn't exactly viable here.
[3] There's a riddle, I believe attributed to Bob Widlar (probably in his "What's All This [Stuff] Anyhow?" series of articles; it's been a long time since I reviewed them and an obvious hit doesn't turn up from a quick search), of how to get negative voltage from a BJT. Of course there are the more obvious cases like making it oscillate from parasitic (lead) inductance or whatever, but there is in fact a static version possible. The trick is this: by avalanching the B-E junction, a little light is produced, along with free charge carriers; both act upon the B-C junction as a photocell, developing some voltage as the carriers are "sucked up" across the junction potential. Typical ratings might be -0.2V at some ~µA, but that can indeed be enough to help pull a "single supply" op-amp (like LM324) all the way to true zero output, for example.
An analogous, and even older, version of this riddle might be the zero-bias current produced by a vacuum tube; indeed there are some similarities in mechanism, i.e. charge carriers freed by some power source, then allowed to drift. In the vacuum tube case, the source is thermal, making it a true heat engine -- albeit an extraordinarily inefficient one (a 6AL5 diode might consume a watt of heater power, and produce a few nanowatts maximum).
These factoids are rarely if ever useful in circuit, but are a fascinating window into the physics at work in these devices.
  • \$\begingroup\$ Thank you, Tim and especially for the bonus analog design analysis! \$\endgroup\$ Commented Dec 1 at 1:30
I wanted to mention AP2502KTR-G1 as a single transistor sized IC that solves the problem in 65mV typical (120mV Max), using Spehro Pefhany's circuit internally:
It's doesn't cost much more than using discrete transistors and should take up less board space.
It's not quite what you asked for since it's 20mA (and only arguably discrete) but you can probably just PWM the enable to bring your power back down.
  • \$\begingroup\$ For the OP's information, according to the datasheet, the Permitted PWM Dimming Frequency is up to 150kHz, which I think is pretty good and pretty flexible. \$\endgroup\$ Commented Jan 27 at 12:43
