I have 4 pairs of "LED + LDR" sensor. I need to be able to switch each of them on/off independently and take reading from the LDRs. To connect all of them to the microcontroller board, I would need 4 output pins for the LEDs, 4 output pins for the LDRs and 4 input pins for the LDRs. The output pins (also the power supply for the components) turn the LEDs and LDRs on/off while the input pins measure the current/voltage from the LDRs. My microcontroller board has only 12 input/output pins, how do I minimize the pins usage? I know the LDRs can be connected to a single input pin via a multiplexer but how do I connect the output pins to the components? A schematic diagram would be very convenient. Thanks.
  • \$\begingroup\$ As far as i can tell, you need 8 pins. 4 to turn on/off LED+LDR pairs. 4 LDR inputs. So where's the constraint? \$\endgroup\$ – ammar.cma Nov 24 '15 at 22:41
  • \$\begingroup\$ Yes that works. But I need to save as much pins as possible, I need to connect many other components to the microcontroller board as well. \$\endgroup\$ – Umar Zain Nov 24 '15 at 22:46
  • \$\begingroup\$ Okay so you can save 3 pins by multiplexing the input. Now you can certainly employ a shift register to turn on/off the LED+LDR pairs. (THAT'S A GUESS!). If the above is correct, You might end up using only 4 pins for the pairs. \$\endgroup\$ – ammar.cma Nov 24 '15 at 22:50
  • \$\begingroup\$ Do you need an analog measurement? If not, then it's relatively easy to use 2 different kinds of shift registers, one for digital inputs and one for digital outputs, daisy-chained as far as you want to go, all controlled by 4 pins: Bit Clock, Data In, Data Out, and Set Data. An almost perfect match for a SPI peripheral. If you need analog, you might be able to get a SPI-based ADC on the same bus as well (no additional pins), but you also have to consider what the shift registers do while you're accessing the ADC and vice-versa. You could get around that by using a second chip-select. \$\endgroup\$ – AaronD Nov 24 '15 at 23:02
  • \$\begingroup\$ Or perhaps you could charlieplex the LED's. (google that) \$\endgroup\$ – AaronD Nov 24 '15 at 23:07
IMG http://i65.tinypic.com/2liblvm.jpg I came up with this circuit. 4 pins are used. Note: I didn't include the clock connection for simplicity. The microcontroller board has a dedicated output pin of its clock, hence this would not affect the amount of input/output pins used up.
| improve this answer | |
  • \$\begingroup\$ Looks good to me. Actually, I'm pretty sure you can get an 8x2 analog mux/demux that does all of that on one chip. It has two 4x1 circuits in it that can pass current in both directions, and that share the 2 select pins. No clock required, but try to set the current to zero before switching. I've stressed these chips to the point of latent failure by switching them with current. \$\endgroup\$ – AaronD Nov 25 '15 at 1:13
  • \$\begingroup\$ @UmarZain This does not fulfill your requirement to have all combinations (2^4 as you mentioned) available. With this configuration, you can select one at a time. \$\endgroup\$ – Daniel Nov 25 '15 at 18:36
  • \$\begingroup\$ @Daniel My idea is to turn on and read current from the sensor(s) one at a time but switching between them quickly and repetitively. For example if I want to use only Sensor1 and Sensor4, I would provide (via pins AO1 & AO2) an input of 00 to the mux and demux for 1ms, then 11 for 1ms, then 00 for 1ms, then 11 for 1ms...on and on until I need a different sensor combination. It might be less hassling with shift registers but I won't be able to get analog readings directly and faster. I can't think of other methods. \$\endgroup\$ – Umar Zain Nov 25 '15 at 23:52
