Last week I bought a transistor BC107 for putting it into use in my common emitter class A audio amplifier. The BC107 transistor costed Rs. 15. Yesterday I bought a 2N3904 transistor that costed only Rs. 6 and it gave me almost the same result as the first transistor. Now my question is, what is the difference between the two, that their cost varies this much. Also what would be the different applications of the two transistors?
5\$\begingroup\$ Have you examined the datasheets yet? \$\endgroup\$ – Ignacio Vazquez-Abrams Nov 26 '15 at 4:24
\$\begingroup\$ See electronics.stackexchange.com/a/81494/54580 Also en.wikipedia.org/wiki/BC108_family and en.wikipedia.org/wiki/2N3904 With respect to price: depends a lot who made them too. \$\endgroup\$ – Fizz Nov 26 '15 at 4:37
2\$\begingroup\$ An obvious difference is that BC107's are in a metal can whereas 2N3904 are plastic \$\endgroup\$ – Icy Nov 26 '15 at 8:15
1\$\begingroup\$ @Icy: If there are fakes like these they might not be in TO-18! As far as I can tell Fairchild never made those. \$\endgroup\$ – Fizz Nov 26 '15 at 9:10
If you look at the datasheets for the 2N3904 and BC107, the main specs to look for are:
2N3904 BC107
max Vceo 40V 45V (collector-emitter voltage)
max Vcbo 60V 50V (collector-base voltage)
max Vebo 6V 6V (emitter-base voltage)
max Ic 200mA 200mA (collector current continuous)
max Icbo 50nA 15nA (current collector cutoff)
max Pd 625mW 600mW (power dissipation)
max Vce(sat) 0.2V * 0.25V ** (collector-emitter saturation)
* @Ic=10mA, Ib=1mA
** @Ic=10mA, Ib=0.5mA
min Ft 300 MHz * 150 MHz ** (switching frequency)
* @Ic=10mA, Vce=20V, f=100 MHz
** @Ic=10mA, Vce=5V, f=100 MHz
min Hfe β 100 * 110 ** (DC current gain)
* @Ic=2mA, Vce=10V
** @Ic=1mA, Vce=5V
So as you can see, most of the specifications are nearly the same. Some specs, such as V\$\small_{CE}\$(sat), f\$\small_{T}\$ and H\$\small_{FE}\$ are specified under certain test conditions, which are not exactly the same for both transistors. The minimum switching frequency supported by the 2N3904 is about double that of the BC107. Unless you are running at very high speeds, the two BJTs should be interchangeable.
Digi-Key uses I\$\small_{C}\$, V\$\small_{CEO}\$, V\$\small_{CE}\$(sat), I\$\small_{CBO}\$, h\$\small_{FE}\$, P\$\small_{D}\$, and f\$\small_{T}\$ as parameters in its selection tool.
As far as costs go, the 2N3904 is a very popular transistor, manufactured in many millions per year. The BC107 is much less common. Digi-Key currently has over 400,000 of the through-hole 2N3904 in stock and ready to ship at 18¢ (12 Rs.) apiece for singles or as low as 3¢ (2 Rs.) in quantity, but has only 830 of the BC107 at $1.91 (127 Rs.) apiece, or as low as 91¢ (60 Rs.) in quantity. So you got a really good deal on the BC107s at Rs. 15.
The prices of the surface-mount version of the 2N3904 at Digi-key are about the same as the through-hole, and they have 110,000 of those ready to ship. As far as I know, there isn't a surface mount version of the BC107, due to lack of demand.
In addition to the savings afforded by volume, the 2N3904 is manufactured in a plastic TO-92 case, whereas the ZBC107 is made in a metal TO-18 can, which would be much more expensive to make:
2\$\begingroup\$ If for any reason you wanted an exact replacement for the BC107 in a modern package, look for a BC547 (TO-92) or BC847 (SOT23). I would expect their price to be closer to the 2N3904. The main difference is European (and probably Mullard/Philips/NXP) vs American origins, to which the BC107 adds its age (close to 50 years) as a factor. \$\endgroup\$ – user_1818839 Nov 26 '15 at 10:50
