enter image description hereI am designing this circuit for testing purpose to test the following conditions.
1.When +12V is applied to the test circuit,my Circuit B should be activated for 2ms and trip open.CKT B is already designed and working fine.During this condition,my CKT A should be inactive. 2.When no power is applied ,my CKT A should be activated.
I am using Normally closed relay in the place of switch(SW), so that my CKT A is always on and inactive when +12V is applied.The minimum response time of the relay I found was approximately 0.5ms.I want to reduce this response time as it will have an impact on CKT B activation time.
Is there any option to use any other switching device to satisfy this condition.
  • \$\begingroup\$ FETs will work much faster than relays, but it is not clear what exactly you want. What generates the 2 ms right now ? \$\endgroup\$
    – jp314
    Commented Nov 27, 2015 at 22:14
  • \$\begingroup\$ How much current does circuit A draw when its active and how much "extra" resistance can be tolerated in series with circuit A before it fails to perform as you would want? \$\endgroup\$
    Commented Nov 27, 2015 at 22:25
  • \$\begingroup\$ Mechanical relay will be far too slow. \$\endgroup\$
    – Autistic
    Commented Nov 28, 2015 at 1:07
  • \$\begingroup\$ @Andyaka: Basically I want my ckt A to be active when there is no +12V applied.Circuit A draw current of 10-20mA from constant current source to measure the resistance. \$\endgroup\$
    – Newbie
    Commented Nov 29, 2015 at 7:21
  • \$\begingroup\$ You said that Ckt A draws 10-20 ma. If it is only on when +12v is off (i.e. normally closed NC contact), where is the current source for Ckt A coming from (since you have it connected to the +12V line and nothing else)? Seems like Ckt A is never really connected to +12V but something else. Is there more to the circuit than you are showing? \$\endgroup\$
    – tcrosley
    Commented Nov 29, 2015 at 16:36
I don't think you need solid state relays and such; they are terribly expensive, at least $35 to get one with a low on-state resistance, and the best turn on/turn off times are in the order of 50-100 µs, not all that better than what you are using now. Instead, you should be able to just use a N-channel FET as a low-side switch. The IPB009N03L has a very low R\$_{DS(on)max}\$ of 0.95 mΩ, a turn-on delay + rise time of 50 ns, and a turn off delay + fall time of 125 ns. It is designed to work with a logic level input since it has a minimum V\$_{GS}\$ of 2.2V. It is available at Digi-Key for $2.87.
The main disadvantage of a low-side switch is the switched circuit is no longer connected directly to ground. However with such a low R\$_{DS(on)max}\$, and currents under 20 mA, it shouldn't matter.
But if you must use a high-side switch, you could use the P-channel IPB180P04P4L-02. It also has a low R\$_{DS(on)max}\$ of 2.4 mΩ, a turn-on delay + rise time of 50 ns, and a turn off delay + fall time of 265 ns. It has a minimum V\$_{GS}\$ of -2.2V. It is available at Digi-Key for $2.20.
