I am trying to implement the verilog code using generate statement.There is issue with taking four bits for calculating P and G values.Added the code below for reference. Cin is taken as Zero.
`timescale 1ns/10ps
module cla_64bit(sum,c_out,a,b,c_in);
input [64:0]a,b;
input c_in;
output [64:0]sum;
output c_out;
wire [65:0]sum_out;
wire [64:0]c_in;
wire [64:0]c_out;
assign c_in[0]=1'b0;
genvar i;
generate
for (i = 0;i<64;i=i+16)
begin : FA
add_16bit FINALBITBLOCK(
.sum (sum_out[i]),
.c_out (c_in[i-1]),
.a (a[i]),
.b (b[i]),
.c_in (c_in[i])
//assign g[i]=a[i] & b[i];
//assign p[i]=a[i] ^ b[i];
//assign c_in[i+1]= g[i]|(p[i] & c_in[i]);
end
assign c_out=c_in[63];
assign sum=sum_out[63:0];
endgenerate
endmodule
module add_16bit(sum,c_out,a,b,c_in);
input [15:0]a,b;
input c_in;
output [15:0]sum;
output c_out;
wire [15:0]p,g;
wire [15:0]sum_out;
wire [16:0]c_in;
wire [16:0]c_out;
genvar i;
generate
for (i = 0;i<16;i=i+4)
begin : FA
add_4bit FOURBITBLOCK(
.sum (sum_out[i]),
.c_out (c_in[i+1]),
.a (a[i]),
.b (b[i]),
.c_in (c_in[i])
end
assign c_out=c_in[15];
//assign sum=sum[15:0];
endgenerate
endmodule
module add_4bit(sum,c_out,a,b,c_in);
input [3:0]a,b;
input c_in;
output [3:0]sum;
output c_out;
wire [3:0]p,g;
wire [3:0]sum_out;
wire [4:0]c_in;
wire [4:0]c_out;
genvar i;
generate
for (i = 0;i<4;i=i+1)
begin : FA
add_full FA(
.sum (sum_out[i:0]),
.c_out (c_in[i+1]),
.a (a[i]),
.b (b[i]),
.c_in (c_in[i])
assign c_in[i]= g[i]|(p[i] & c_in[i]);
end
assign c_out=c_in[3];
assign sum=sum_out[3:0];
endgenerate
endmodule
module add_full (sum, c_out, a, b, c_in);
output sum, c_out;
input a, b, c_in;
wire w1, w2, w3;
add_half M1 (w1, w2, a, b);
add_half M2 (sum, w3, w1, c_in);
or M3 (c_out, w2, w3);
endmodule
module add_half (sum, c_out, a, b);
output sum, c_out;
input a, b;
xor M1 (sum, a, b);
and M2 (c_out, a, b);
endmodule
-1
quite so many times if you actually started using zero indexing... e.g.for (i=0;i<64;i=i+1)
. \$\endgroup\$.sum (sum_out[i-1:0]),
why? \$\endgroup\$.c_out (c_in[i]),
andassign c_in[i]= g[i-1]|(p[i-1] & c_in[i-1]);
both assign a value to the same bit ofc_in
. Why? \$\endgroup\$c_out
. \$\endgroup\$
