So I am trying to understand I guess what is probably a basic concept of computers. I was taking a look at this previous question: From Transistor to Gates
And it's accompanying link: http://www.cs.bu.edu/~best/courses/modules/Transistors2Gates/
So let me get this straight, we use Transistors to build logic gates correct? Are these all usually Bipolar Junction Transistors? I also see that we also stuff multiple gates into an IC like so: http://www.kpsec.freeuk.com/components/74series.htm (Btw most of these have like....4-6 logic gates within them....is there such thing as a SINGLE gate you can buy, or would you have to build that single NOT/AND/OR/Whatever gate out of other transistors)
So...like for example, the IC's above....are those built using CMOS technology or TTL? Im a bit confused at what the difference between a TTL built transistor and a CMOS transistor. Like is this a TTL transistor or a CMOS transistor? (it is a biopolar one correct?):
TTL or CMOS?
I know this is a lot of questions, but Im just trying to understand how we go from Transistors to Gates to IC's. I mean.....the IC's I linked above (like the 74 series Logic IC's) are built from gates.....which must be built from transistors (CMOS or TTL?) But how come we never see like SINGLE gates being sold.....and if that's so then why do big transistors such as the one above exist if we can fit 6 logic gates in a small IC.
And do FET's come into play in Logic Gates at all....or not so much.
Whew....
edit: ALSO any books/websites that talk about this is a HUGE help as well.
    \$\begingroup\$ Single gates are readily available as surface mount devices (SMD) -- go to this page and select Number of Circuits = 1 \$\endgroup\$
    – tcrosley
    Oct 1, 2011 at 0:48
  • \$\begingroup\$ @tcrosley I guess you won't see them as normal...whatever you would call non-SMD? \$\endgroup\$
    – user3073
    Oct 1, 2011 at 0:59
    \$\begingroup\$ @Sauron - The word for non-SMT is through-hole. \$\endgroup\$ Oct 1, 2011 at 1:34
    \$\begingroup\$ @Sauron, although through-hole components are still popular with hobbyists, and for professionals building prototypes on a breadboard, surface mount components are now the "norm" for commercial printed circuit boards and have been for the last 15 or more years. You are right, I have never seen single gates with a low number of inputs in a through-hole package. \$\endgroup\$
    – tcrosley
    Oct 1, 2011 at 9:16
  • \$\begingroup\$ @tcrosley Ah, gotcha. I guess SMD are prolly cheaper to produce in large quantities...plus they are so much smaller. Thanks for the Info though. \$\endgroup\$
    – user3073
    Oct 1, 2011 at 16:31
12
The first comprehensive logic series was the TTL series 74xx. This used BJTs (Bipolar Junction Transistors). Later there came variants like the often used 74LSxx, where the "LS" stands for Low-power Schottky TTL. As the name implies these used less power than the rather power-hungry TTL, and were faster too. At the same time the CMOS 4000 series was developed. The "C" in CMOS stands for Complementary, meaning it's a combination of N-channel and P-channel MOSFETs. Their construction is simpler than TTL and they use far less power. Later standard CMOS developed into HCMOS, "H" for High-speed. Most 74LSxx types have been released as HCMOS in the 74HCxx series, or the 74HCTxx series, which is TTL compatible. Later more variants were developed, like Advanced CMOS (74ACxx).
Microcontrollers are built in HCMOS technology, so they use MOSFETs. AFAIK JFETs aren't used for logic ICs. The transistor you show in the picture is a BJT, which you can tell from the pin designation:
E = Emitter
B = Base
C = Collector
For a MOSFET the pins would be
S = Source
G = Gate
D = Drain
respectively.
Many ICs in the 74HCxx series were originally released in 14 or 16 pin DIL packages, which meant that they would fit four 2-input gates. With miniaturization (SMT) came the demand for smaller packages, even if they contained less gates. Several manufacturers offer single-gate and dual-gate versions of logic gates. For example, NXP has a 74LVC1G00 (single 2-input NAND) and a 74LVC2G00 (dual 2-input NAND) version of the classical 74HC00. 74LVCxx is yet another HCMOS technology. This page lists all NXP logic families.
  • \$\begingroup\$ So most IC's I will be working with (as in built in logic gates and such) will be HCMOS? And you say CMOS uses N-channel and P-channel.....what exactly does "channel" mean. \$\endgroup\$
    – user3073
    Oct 1, 2011 at 5:10
    \$\begingroup\$ "The first comprehensive logic series was the TTL series 74xx" -- I thought RTL and DTL preceded TTL ? \$\endgroup\$
    – Paul R
    Oct 1, 2011 at 7:26
    \$\begingroup\$ I wonder why the community seems to think this is a better answer than mine... perhaps it suffers from TL;DR \$\endgroup\$
    – vicatcu
    Oct 1, 2011 at 17:30
    \$\begingroup\$ Out of curiosity, were there any popular mixed-gate configurations of 74xx-style logic? I know lots of circuits were built out of 7400 NAND gates; I would expect many such circuits would have at least three NAND gates that fed exactly one other NAND gate each. I don't think I've ever seen a DIP14 with three pairs of NAND gates (gate #1 of each pair has two inputs tied to pins and a buried output; gate #2 has one input tied to a pin and one input tied to the output of gate 1) but I would think such a device would have been very widely useful. \$\endgroup\$
    – supercat
    Oct 2, 2011 at 17:11
    \$\begingroup\$ @Sauron - It's never too late to ask a good question! :-) You may find this and previous/following pages useful. Clearly explained with good diagrams. For book titles I'd suggest you search previous questions here. I don't have any title in mind (learned all this from college courses). \$\endgroup\$
    – stevenvh
    Oct 3, 2011 at 14:19
8
Where to start...
Logic Gates used in VLSI chips are not constructed from Bipolar Junction Transistors (BJT) but rather use Field Effect Transistors (FET) (Metal Oxide Semiconductor (MOS) to be exact). The topologies used in this realm are commonly composed in Complementary P-type pull-up and N-type pull-down networks. Basically I think these types are used in this context because they can be created by a reliable manufacturing process on a very small scale. Perhaps more important is that in CMOS, what counts is the voltage levels, noise margins and switching speeds. All things that are very important in computing technology.
TTL Gates (ala the 7400 series) are integrated (IC) versions of the 3-terminal BJT's as you show in your picture except not quite. They are integrated into appropriate topologies (including integrated "resistors") such that they logically behave as boolean gates from an input/output voltage perspective. Some of the BJT's used in these gates also tend to have multiple emitters for inputs (this is equivalent to multiple 3-terminal BJTs with their collectors and bases connected together). TTL is logically similar to CMOS technology, but the gates can actually drive and sink an appreciable amount of current (e.g. 20 mA+).
The 3-terminal BJT devices tend to have much higher current carrying capacity than the integrated versions, but I'm sure you can find integrated varieties that are comparable. 100mA is common, and upwards of 1A are available. You can immitate TTL logic topologies with them, but that is rarely, if ever, done in practice.
One last thing I'll add is that the terminals of BJT's are commonly labelled E for emitter, C for collector, and B for base. The terminals of a FET are commonly labeled S for source, D for drain, and G for gate (not to be confused with a "logic gate"). The terminals are sort of analogous, but when employed to implement "logic circuits," the topologies are much differnt for these two technologies.
This question already have two good answers, but it's worth mention that this subject is quite extensive to go deep into all the details without writing too much. I highly recommend you to watch these MIT lectures, it's long but worth every minute:
http://ocw.mit.edu/courses/electrical-engineering-and-computer-science/6-002-circuits-and-electronics-spring-2007/
Lectures 4 and 5 cover what you asked, and lecture 13 is a good addition.
