I have a portable diagnostics tool which communicates with an electronic appliance using which I believe is Synchronous Serial Interface (SSI).
I'm looking for a way that I can extend the range of this tool over LAN so that a the appliance can be connected to PC1, and the tool to PC2, and software running on both PCs bridge the SSI over LAN.
This is a circuit diagram showing the tool connection to the appliance board with inputs labelled SCK, CLK, RXD, TXD, VCC, GND: (I have already established that the tool can be powered directly by applying 5V between VCC and GND).
