I am trying to interface a ADXL345 to 8051 - AT89C51RC2 through SPI interface.
I have used the below code taken from here:
include "Init.h"
define SS_ADXL P1_0;
void SPI_interr_routine(void);
char serial_data;
char data_example;
char data_save;
char transmit_completed;
void main(void)
// Insert code
Hardware_init();
transmit_completed = 0;
data_example=0x55;
data_save = 0;
printf("\n\r1111111111111");
SPCON |= 0x10; /* Master mode */
P1_1=1; /* enable master */
SPCON |= 0x82; /* Fclk Periph/128 */
SPCON &= ~0x08; /* CPOL=0; transmit mode example */
SPCON |= 0x04; /* CPHA=1; transmit mode example */
IEN1 |= 0x04; /* enable spi interrupt */
SPCON |= 0x40; /* run spi */
P1_1 = 0;
EA=1; /* enable interrupts */
//while(1) /* endless */
SS_ADXL = 0;
SPDAT= (0x32 | 0x80); /* send an example data */ //
while(!transmit_completed);/* wait end of transmition */
transmit_completed = 0; /* clear software transfert flag */
SPDAT=0x00; /* data is send to generate SCK signal */
data_save = serial_data; /* save receive data */
SS_ADXL = 1;
printf("\n\r%c data_save = " , data_save);
void it_SPI(void) __interrupt (9)
SPI_interr_routine();
return;
if((SPSTA & 0x80) == 1)
serial_data = SPDAT;
transmit_completed=1;
return;
Hardware Connections :
I have used this logic level converter to connect the 8051 to ADXL345.
P1.1 (SS) pin of 8051 is unconnected and I am enabling it in software by setting P1.1 to 1.
The CS pin of ADXL345 is connected to a GPIO of 8051 and I am selecting the slave (ADXL345) by setting the GPIO pin to low before writing / reading and then setting it high. I am using the inbuilt SPI module in 8051.
When I run the above code, the SPIF bit is not getting set.
please let me know if anything is wrong with the hardware connection or the code.
Thanks
