I am examining op amps and I found this pdf very helpful: http://www.aicdesign.org/SCNOTES/2010notes/Lect2UP230_(100327).pdf
In this tutorial, the op amp circuit topology is given as this: op amp topology
and gains of stages of the op amp are given like this:
gain equations
First time I see an equation like this. I thought the (DC)gain of the first stage is: \$gm_{2} * r_{ds2} // r_{ds4}\$
it seems really wrong to me. Can anyone explain why the gain is represented that way in this tutorial?
  • \$\begingroup\$ can you specify the page no. of this tutorial in above pdf \$\endgroup\$ – Virange Nov 30 '15 at 9:31
  • \$\begingroup\$ on page number 4. \$\endgroup\$ – Alper91 Nov 30 '15 at 9:33
  • \$\begingroup\$ @Alperözel hope my explanation helps \$\endgroup\$ – Ashik Anuvar Nov 30 '15 at 15:26
gds = 1/rds => conductance add up when you have parallel resistances.
G = 1/R
R1 || R2 = 1 / (G1 +G2)
Thus, rds2 || rds4 = 1/ [(gds2 + gds4) ]
So, GAIN for the first stage;
Av = gm2 * (rds2 || rs4) = gm2 / (gds2 + gds4)
here since m1 and m2 are differential pairs ,its ok to assume that their trans conductances are almost same (gm1 =gm2).
Part2:
Regarding the expression in terms of current ,
The drain resistance (rd) is due to channel length modulation and is given by :
rds = 1/ (lambda * Id) or gds = ( lambda * Id).
So replacing gds, we get;
Av= gm2 / [lambda*(Id2 + Id4) ]
