I'm new to the world of etching PCBs. I etched my first board yesterday, and though it was a success I didn't like the PCB look. I saw this picture (attached) and I like the material of this boards and would like to know what it is.
example1: enter image description here
example2: enter image description here
Please give me links that talk about PCB boards types.
It's single sided FR4, the most common material in use for PCBs nowadays. You can buy this from any good electronics vendor (example from Farnell)
For etching purposes you can buy it precoated with UV photoresist, for use with a mask and UV light box.
The Wiki page will tell you about all the different types.
  • \$\begingroup\$ Can i use it with the Toner transfer method ? \$\endgroup\$
    – Rain
    Oct 1, 2011 at 9:08
  • \$\begingroup\$ Yes, you can use the plain FR4 with toner transfer. Here is a link that might be of some use. \$\endgroup\$
    – Oli Glaser
    Oct 1, 2011 at 9:13
    \$\begingroup\$ Note that FR4 requires special cutting equipment - not like the cheap Paper Epoxy boards. You will need Tungsten Carbide drill bits, or you will find them blunting almost instantly. Also, cutting the board itself is much harder and you really require a board guillotine, or a Tungsten Carbide router. Also, the dust is much more hazardous than paper-epoxy as it contains glass. \$\endgroup\$
    – Majenko
    Oct 1, 2011 at 9:19
I use this FPC 16 paper composite material (about half-way down the page) for my home-made boards:
http://www.megauk.com/pcb_laminates.php
It's much easier to cut and drill than FR4, and is somewhat cheaper. It has the disadvantage of not being translucent, like FR4.
It only seems to be available with resist, so it isn't suitable for toner transfer. It might be possible to buy it without resist, but it would probably require a large order.
  • \$\begingroup\$ Are those the white PCBs you've shown us pictures of? \$\endgroup\$
    – stevenvh
    Oct 1, 2011 at 14:13
  • \$\begingroup\$ Yes. I often get asked about my white PCBs. \$\endgroup\$ Oct 1, 2011 at 15:11
