-2
I've a handset which i was using with my galaxy ace 4 then changed to experia z1 Anyway the handset butom was raising volume instead of pausing and then the jack was giving static and then it was done So i googled and founs that i can fix it Searched in my city for TRRS jack and didn't found So I got a TRS Jack drom radioshack and then tried to connect Basically i can't wire what where all working and even tried putting ground to the highest one then putting the red and green wores together on one of the 3 conductors and it worked so maybw ican use the mic as well? If not where to wire what? I mean there's red green black and copper Red green is the headphones and black is mic and the forth is the ground There's 2 conductor and both have same height
What i noticed is i must put one of the red or green on the highest then the other on any and it would work
Edit (01);
I've a samsung hand set using it on experia phone. Its jack.got messed up (like always). Went to radioshack didn't find a 3.5mm jack with four conductors so i got a 3 conductors one and decided that i don'tneed mic As you can see on top the 3 conductor one got 2 pins of the samw height so i don't know what's ring and what's tip The second one is the old jack which is 4 conductors (left right mic ground)
The third is the wires which is green red black copper
Tried to connect it and it seems to work if i connect one of the (red/green) to the highest pin and the other to any one of the lower ones without even connecting ground
Googled again found a reddit post about a guy who want to do the same and cancel the mic and he messed up with colors But i googled and found an adapter trrs to trs so if that works i think i can make the mic work as far i understand that you can connect one (red/green) with the copper and connect the other one and connect the black (mic) to the third I wanted to try but i'm afraid to make a mistake that harms the device so asked for help Hope this is more understandable The Pic; http://imgur.com/HogpfnQ enter image description here
TL;dr: 1. How to use a TRS Jack instead of TRRS of the handset
  1. Can i make the mic work?
  2. Which is the tip and which is the sleve and which is the ring as there's two of the same height Thanka guys
Edit (2): So i connected as following Sleeve: black warpes around copper (common/ground and mix) Ring: red wire (right audio) Tip: green (left audio)
[![enter image description here][2]][2]
Instead of the standard for 4 conductors which ia from sleeve to tip is mic ground right left
I don't know if this will harm the phone or the handset or not really. Thanks
    \$\begingroup\$ Welcome to SE! This looks like the beginnings of a good question, but there are two things that would make it worth the experts' time: 1) Break up the wall of text into something a bit more readable. We get lost easily. 2) Add a schematic of what you're trying to do. Most of us think graphically and spend considerable effort to translate words into pictures, so if you can just give us those pictures it would be that much easier to understand you. Thanks! \$\endgroup\$ – AaronD Nov 30 '15 at 17:03
  • \$\begingroup\$ Sorry i'm using android so it's kinda bad i'll supply images but drive isn't working so i'll find another server and edit \$\endgroup\$ – Mohamed Amr Nov 30 '15 at 21:11
  • \$\begingroup\$ Yeah, the Android app is more of a "stay connected" sort of thing and not particularly useful for a complete question or answer. \$\endgroup\$ – AaronD Nov 30 '15 at 21:17
  • \$\begingroup\$ I don'thave access to a Computer. Try playing hearthstone on an mobile and not miss swiping. \$\endgroup\$ – Mohamed Amr Nov 30 '15 at 21:26
  • \$\begingroup\$ I edited the poat dude \$\endgroup\$ – Mohamed Amr Nov 30 '15 at 21:27
It appears that there is no official standard, so this is not guaranteed, but the one that works for me is:
  • T: Left Speaker
  • R: Right Speaker
  • R: Ground
  • S: Mic
In that order. The most common variation that I see documented is to swap Mic and Ground, but I haven't seen that in my limited sample size. I think I've heard of another one that puts the Mic on the Tip, but don't quote me on that.
I would make some reliable but easily removed connections per the above and test it. See if you get all the right signals in the right places, adjust as necessary, and make it permanent when you get it right.
The one thing to be careful about in most cases is accidentally connecting two outputs together, which you don't have to worry about here because you're throwing away the mic.
If you want to salvage the mic, you'll have to settle for mono headphones instead of stereo, and I have no idea what the pinout is for that.
I will say, however, that you shouldn't just connect Left and Right together. That makes two outputs fighting each other, and you may not like the result. You could throw away Left or Right and keep the other, but that would ruin some music. Or you could put a resistor in series with each one and then tie the resistors together, but that can make certain headphones sound weird. A powered buffer/amplifier would fix that, but then you'd need one of those.
| improve this answer | |
  • \$\begingroup\$ Thanka but my new jack is trs and i can't seem to know which is tip and which is ring \$\endgroup\$ – Mohamed Amr Nov 30 '15 at 22:16
  • \$\begingroup\$ @MohamedAmr The two rings get combined into one for a total of 3 connections instead of 4. So it's Tip/Ring/Sleeve instead of Tip/Ring/Ring/Sleeve. As for the signal names, slide the S: up in my description to replace the first R: and then delete the Mic line entirely. That's the standard for 3-pin stereo headphones. \$\endgroup\$ – AaronD Nov 30 '15 at 22:20
  • \$\begingroup\$ pinoutsguide.com/HeadsetsHeadphones/… \$\endgroup\$ – Mohamed Amr Nov 30 '15 at 22:21
  • \$\begingroup\$ @MohamedAmr Yep, that matches mine for the 4-pin version. \$\endgroup\$ – AaronD Nov 30 '15 at 22:21
  • \$\begingroup\$ Look at the new jack on the picture you can see the tip and ring the same height how to differentiate \$\endgroup\$ – Mohamed Amr Nov 30 '15 at 22:22
My other answer was based on an incorrect understanding of the problem, but it does have some good information so I'll leave it.
To determine which ear to solder to for each contact, you can look closely at the stackup and understand that it's all concentric. This means that the layers have to "peel off" in order from outside to inside on both ends, so you can just count the insulator layers between tabs.
Here's a different design that shows this better: From here: http://ch00ftech.com/2011/12/27/the-ch00f-o-scope/
Or you could use a continuity checker.
