Is there a difference between the serial configuration devices from Altera and any other SPI flash memories? I see Terasic uses S25FL256S in their development board instead of EPCQ256, so I wondered how the Quartus II will confirm the device?
  • \$\begingroup\$ Has your question been answered? \$\endgroup\$ – andrsmllr Dec 18 '17 at 21:13
Each EPCS device has a so called "silicon ID" which can be used to identify its type, which can then be used to look up the size of the flash memory. Quartus II can read this value and then check e.g. if the device is large enough for the generated bitstream.
There is a neat documentation about structure and operation of Altera EPCS devices, to be found on the Altera homepage. You can think of EPCS devices as a special type of SPI flash with a few special features for storing bitsreams used to program your FPGA. It's just a little less fuzz to use an EPCS than a standard SPI flash with your Altera FPGA.
| improve this answer | |
