I have a capacitor that controls frequency for a specialty IC with the relationship
\$F \propto 1/C\$
I want to be able to get a number of frequencies in evenly spaced intervals. Currently I have a string of series capacitors some of which I short out with regular dip switches in a binary code to give 16 steps.
This works as adding capacitors in series follows the relationship below giving linear steps.
\$ F \propto \frac{1}{C} = \frac{1}{C} + \frac{1}{2C} + \frac{1}{4C} +\frac{1}{8C} \$
To make it more intuitive to set the frequency for people who are not used to binary code I would like to use a coded rotary dip switch such as this
This means the switches are not all separate and have a common pin.
Because of this the relationship is exponential and it is not possible to get even steps based on this circuit
\$ F \propto \frac{1}{C} = \frac{1}{C + 2C + 3C+ 4C}\$
TLDR
Is there a simple way to get evenly spaced frequency steps using a coded rotary dip switch, without needing too many more components.
