I'm trying to switch an el wire segment on and off by using a z0103ma triac. I have the AC current connected across pins 1 and 3, and when the gate is closed, the ac current is interrupted, but once I connect the gate to a digital output pin on my arduino, the gate is open and current flows, regardless of what voltage (0 or 5 volts) I put onto the gate.
Am I doing something wrong? What signal do I need to send to the gate to open and close the triac?
    \$\begingroup\$ How are you referencing the Arduino to the line voltage? \$\endgroup\$
    – vini_i
    Commented Dec 3, 2015 at 2:05
    \$\begingroup\$ Dont electrocute yourself. \$\endgroup\$
    – Autistic
    Commented Dec 3, 2015 at 2:35
The MOC3041 is indeed a suitable optocoupler to use -- figure 15 in the datasheet (reproduced below) is your reference, by the way. You don't need a DIAC with an optoTRIAC/TRIAC combo, and the MOC3041 is in a 6 pin DIP -- pins 1/2 are the LED and 4/6 are the optoTRIAC.
Figure 15 from the MOC3041 D/S
In the following schematic; remove the potentiometer and and replace the DIAC with a TRIAC optocoupler. Operate the LED in the optocoupler with the Arduino like an ON/OFF switch.
Here is an example of what you would be looking for. Pin 3 and 4 go instead of the DIAC. Pin 1 and 2 are an LED that with the help of a resistor can be turned on and off with the Arduino. This is the safe way to do this because the Arduino is fully isolated from mains voltage. enter image description here
  • \$\begingroup\$ The MOC3041 doesn't need a DIAC, nor is the pinout you give for it correct. \$\endgroup\$ Commented Dec 3, 2015 at 3:40
  • \$\begingroup\$ @ThreePhaseEel Sorry, i was at the mercy of the illustration. I was going more for a picture of a TRIAC optocoupler than an actual part. \$\endgroup\$
    – vini_i
    Commented Dec 3, 2015 at 11:31
