I am designing a consumer Li-ion powered system with the following constraints:
  1. The system volts has to be 3.3V
  2. Li-Ion battery charging range is 2.8 - 4.2V
  3. Charging is to be done via a standard USB charger.
  4. All aspects of battery charging - charging profile, safety timers, input current programming etc are expected.
  5. [Desirable] the battery and system is isolated via switch.
I have been searching for "power management ICs" and "Li-ion battery chargers". So far my results have all yielded a battery charger IC only - on battery backup, system volts follow battery volts. I would want an internal buck-boost regulator to provide regulated 3.3V o/p.
e.g BQ40z60, TPS6502x, TPS6502xx, Max77818, LTC4040 (step up regulator only!)
A boost regulator will not work since system volts need to be @ 3.3V (and not at 5V)
My current solution has a BQ24250 for the battery charging and then a TPS63030 as a buck-boost regulator.
Questions:
  1. Are such ICs even available?
  2. Please recommend some.
Thanks!
  • \$\begingroup\$ I have read about good experiences of using MCP73831 from MICROCHIP many times. \$\endgroup\$ – Mahmoud Hosseinipour Dec 3 '15 at 6:30
  • \$\begingroup\$ Thanks but thats a battery charger only. \$\endgroup\$ – MindFlayer Dec 3 '15 at 7:18
