I have a CD4021BE set up very similarly to the Arduino ShiftIn Tutorial (the main difference being that I don't currently have 8 buttons so have just connected PI-5 to PI-7 to ground with a resistor, I get the same misbehaviour if these are left floating).
All of the values that I'm getting are being shifted up 1 bit, so with 5 buttons connected to PI-1 to 4 and PI-8), pressing the one connected to PI-1 gives me the value 00000010, pressing PI-2 gives me 00000100 and PI-8 just gives me 00000000.
I have my data pin connected to Q8, which as far as I can see in the Datasheet is the right place. Just to see what happened I connected it to Q6 and get 00001000 from PI-1 and so on.
I got 5 of these chips when I ordered them and have tested 3 so far and all perform in the same way, which really just suggests that I'm doing something stupid.
This is the code I'm currently using:
#define CLK 10
#define LATCH 9
#define DATA 8
int data;
void setup() {
  Serial.begin(9600);
  pinMode(DATA, INPUT);
  pinMode(CLK, OUTPUT);
  pinMode(LATCH, OUTPUT);
  Serial.println("Begin...");
void loop() {
  digitalWrite(LATCH, HIGH);
  digitalWrite(LATCH, LOW);
  data = shiftIn(DATA, CLK, MSBFIRST);
  Serial.println(data, BIN);
  delay(500);
CLK is connected to CLOCK on the chip, and LATCH is PARALLEL/SERIAL CONTROL.
Why is this happening?
After much further googling, I found an 'answer' of sorts. An Issue on the Arduino implementation of shiftIn() with a workaround:
There is a workaround: If you turn the clock on before turning the control flag down, you avoid the extra positive clock transition. digitalWrite(shiftClock, HIGH); digitalWrite(shiftControl, LOW); I'm not sure if this is a bug or a missing feature. The problem is that the first bit is already on the Q8 output when first positive clock transition happens in shiftIn. I think this is what is described in the datasheet as "In the HCC/HCF4021B, the CLOCK input of theinternal stage is ”forced” whenasynchronous parallel entry is made".
I added a CLK high between the LATCH pulse and it now works:
void loop() {
  digitalWrite(CLK, HIGH);   // Set clock high to catch first bit.
Just when I feel like I've actually started to get the hang of things I start hitting weird bugs in the libraries!
