16
Is there any example, preferably by photos, how does assembly layer on PCB differ from the silkscreen? I understand, that silkscreen reference designators should be left visible after the parts are mounted on the board, and assy layer information can be obstructed after the assembly process. Is that the only difference? I cannot find any exact information on this over the internet, everything I have found is a unclear to me. Thank you.
21
Dave's answer is a good one and correct in that assembly layer is not included on the pcb, it is simply to aid the assembly, just wanted to add a bit to it.
The assembly layer is useful for setting up the pick and place machine in that you can make the reference designators very large and put them in the middle of the part so there is no confusion as to what part the refdes is for. You can also put large dots to indicate where pin 1 is. On busy boards with lots of closely spaced parts, an assembly layer can be invaluable since it will prevent the assembly company from contacting you with questions (I have had an order put on hold before because they were not sure where pin 1 was on a part due to poor assembly layer on my part).
See below picture for an example of how assembly layer is useful. Note that it is very easy to see with the bare eyes which part is which refdes as opposed to having small silkscreen refdes numbers next to each part. Also note the dots in the corner of some of the parts, clearly indicating where pin 1 is located. You can also see some parts crossed out in red, indicating they are do not place.
  • \$\begingroup\$ Now I am not sure which answer to accept, since you included the clear image, but Dave was faster. \$\endgroup\$ Commented Dec 4, 2015 at 20:14
  • \$\begingroup\$ @delmadord - I'd go ahead and accept his. Mine is more of an addition to his than a better answer to the question. :] \$\endgroup\$
    – I. Wolfe
    Commented Dec 4, 2015 at 20:28
  • \$\begingroup\$ I'm still upvoting both, both are excellent answers \$\endgroup\$
    – DerStrom8
    Commented Dec 4, 2015 at 21:07
17
The "assembly layer" is not something that gets included in the actual physical PCB, it's just a drawing that becomes part of the documentation that accompanies it. The assembly drawing typically contains more detail than the silkscreen, and is used by the personnel who are assembling parts to the board (either directly or by programming a pick-and-place machine).
  • 5
    \$\begingroup\$ For instance, the assembly layer can write over pads. For hopefully obvious reasons, the silkscreen needs to steer clear of those. \$\endgroup\$
    – Ecnerwal
    Commented Dec 4, 2015 at 14:30
