I am trying to convert highly parametrized VHDL code to verilog. This VHDL code uses good amount of packages and records and I couldn't find the substitute for those in verilog. Also I am just 3 days old in verilog.
Package and entity files in VHDL are as follows:
package control_package is
type control_ca_out is record
   reset           : std_logic;
   end record;
type control_in is record
  clk             : std_logic;
  ha              : psl_control_in;
  dc              : dma_dc_out;
end record;
type control_out is record
  ca              : control_ca_out;
  ah              : psl_control_out;
  cd              : dma_cd_in;
end record;
entity control is
port (
   i                           : in  control_in;
   o                           : out control_out
end entity control;
Package and entity are in separate files. How do i implement the same in verilog? I know there's a way of packing all fields of records in single vector and then use part-select to access different fields of record. How could I include them in separate module in verilog?
    \$\begingroup\$ You should seriously consider using SystemVerlog as this would be quite trivial to convert to a struct And SystemVerilog has packages. There is no such construct in Verilog. \$\endgroup\$
    – dave_59
    Dec 4, 2015 at 17:14
  • \$\begingroup\$ I think i would switch to SV. \$\endgroup\$
    – Ishan
    Dec 8, 2015 at 17:01
