I wrote clock generator module, i dont know if it is true but the problem is in my reg module. The error is:
ERROR:HDLCompilers:246 - "UpDownCounter.v" line 74 Reference to scalar reg 'clk_1Hz' is not a legal net lvalue
ERROR:HDLCompilers:102 - "UpDownCounter.v" line 74 Connection to output port 'clk_1Hz' must be a net lvalue
1 HZ CLOCK GENERATOR
module slowClock(clk, reset, clk_1Hz);
input clk, reset;
output clk_1Hz;
reg clk_1Hz = 1'b0;
reg [27:0] counter;
always@(posedge reset or posedge clk)
begin
    if (reset == 1'b1)
        begin
            clk_1Hz <= 0;
            counter <= 0;
        end
    else
        begin
            counter <= counter + 1;
            if ( counter == 25_000_000)
                begin
                    counter <= 0;
                    clk_1Hz <= ~clk_1Hz;
                end
        end
end
endmodule
And here my Reg 4 bit module
module Reg4(I, Q, clk, reset);
input clk, reset;
input [3:0] I;
output [3:0] Q;
reg [3:0] Q;
reg clk_1Hz = 1'b0;
slowClock clock_generator(clk, reset, clk_1Hz);
always@(posedge clk_1Hz) begin
    if (reset == 1)
        Q <= 4'b0000;
    else
        Q <= I;
end
endmodule
Can u see my problem ? :(
    \$\begingroup\$ You got your answer, but in the future please add a comment telling us which line is the one with the error (line 74, in this case). \$\endgroup\$
    – The Photon
    Dec 6, 2015 at 1:25
In the Reg4 module, change:
reg clk_1Hz = 1'b0;
to:
wire clk_1Hz;
  • \$\begingroup\$ thanks. It worked but the warning is: CLK Net:value_reg/clock_generator/clk_1Hz may have excessive skew because \$\endgroup\$
    – funky-nd
    Dec 6, 2015 at 0:33
  • \$\begingroup\$ however, my project on basys-2 is working well despite warning \$\endgroup\$
    – funky-nd
    Dec 6, 2015 at 0:33
    \$\begingroup\$ @cihangirND add a BUFG primitive between your 1Hz clock register and the output of the slowClock module. Otherwise the clock signal will be routed on normal routing networks and not the global clock network (which is what the excessive skew warning is about). \$\endgroup\$ Dec 6, 2015 at 2:02
  • \$\begingroup\$ @TomCarpenter wow thanks. 0 warning. did i placed it right ? i.hizliresim.com/82a3Ed.jpg \$\endgroup\$
    – funky-nd
    Dec 6, 2015 at 2:22
  • \$\begingroup\$ @cihangirND Indeed. I would have placed it inside the slowClock module for neatness, but when synthesised it will make no difference at all. \$\endgroup\$ Dec 6, 2015 at 2:24
In the 1Hz code you haven't assigned any value to the clk_1hz. Hence no value will be assigned to it. Just include assign clk_1hz = counter[24]; outside the always block.
