Hi I am new to electronics, and I have made a light tripwire using an Arduino Uno. I made this on the idea that electricity follows the path of least resistance, which I now know to be false (https://physics.stackexchange.com/questions/5670/electricity-takes-the-path-of-least-resistance). False or not however, my tripwire works exactly as I would expect it to.
I programmed my board to sound an alarm if pin 2 reads low voltage I thought it worked because if the photoresistor has less resistance than the resistor, then it would read high voltage and vice versa. So can anyone explain what is happening?
  • \$\begingroup\$ Sorry, I'm new to electronics and don't know the resistance of R1 (I don't know how to read colour codes). \$\endgroup\$
    – TheSporech
    Commented Dec 7, 2015 at 16:14
  • 4
    \$\begingroup\$ too bad that there are no resources on the interwebs on how to easily read them \$\endgroup\$
    – PlasmaHH
  • \$\begingroup\$ Lookup voltage dividers and calculate the voltage at your pin for various light situations. \$\endgroup\$
    – Arsenal
    Commented Dec 7, 2015 at 16:26
It's called a voltage divider. "The path" does not change. The current changes, because the total resistance LDR1+R1 changes while the voltage applied remains fixed, so the voltage across R1 (which is what you are measuring at U1 pin 2) changes.
  • \$\begingroup\$ Cool thanks, that sounds like what i'm looking for. \$\endgroup\$
    – TheSporech
    Commented Dec 7, 2015 at 16:44
