I have to calculate the resistance R_AB, R_AC and R_CD. But I'm confused because there are two different terminal, one on the left and one on the right. Can someone give me a hint how to solve this?
If you were to draw out the circuit with just the terminals mentioned you would get this.
The wood should now be separated from the trees.
  • \$\begingroup\$ Hi thx for the pictures :) I understand it now. It was simple, but sometimes your thoughts need a push to thing about it differently. \$\endgroup\$ Dec 8, 2015 at 19:13
Not sure why are you confused. For R_AB there are only two terminals, both on the left. For R_AC one is on the left and one on the right. For R_CD both are on the right.
You should just ignore unused terminals and solve the schematics using the rules of parallel and series resistors. Or Kirchgoff / Ohm laws.
For example for R_AB the C is ignored, you can erase it to the closest junction (but leave the resistors 10 and 10 connected). For R_AC you erase both B and C and then erase the 30 resistor since its bottom terminal is not connected anywhere.
