I’m trying to identify the kind of connector I need for a few DC fans, but can’t track them down on digikey. Pictures attached. Pitch is 2.00mm, wire is 26AWG. The replacement fans I possess have bare wires so I also need to attach the little metal clips (I guess?)
  • \$\begingroup\$ Is the pitch really 2.00mm - ie have you measured accurately? If so the answer doesn't match your question because that's a 2.5mm pitch. \$\endgroup\$
    – PeterJ
    Commented Dec 8, 2015 at 15:56
  • \$\begingroup\$ I put the terminal against a row of 2.54mm pitch headers I had next to me, and the terminal spacing was a touch smaller than the header pin spacing. I will measure more accurately tonight and add a comment. \$\endgroup\$ Commented Dec 9, 2015 at 0:21
It is a Japan Solderless Terminal / JST XH series, female 2 pin variation.
JST XHP-2 on Digikey http://www.digikey.com/product-detail/en/XHP-2/455-2266-ND/555485
The crimp terminals needed are linked on the Digikey page under related parts.
