The BAK 18650CA-2S-3J is a 2S 7.4V battery I am interested in using - however I am unsure of the workings of the device. The image here (and farnell page) shows a 3 cable interface - what is the purpose of the third (middle?) cable? is it for balanced charging only, or is there a 3.7V source also available form here?
Further, what type of chargers are appropriate, with the correct 3 terminal connection to charge this battery?
  • \$\begingroup\$ The second part is a recommendation request and is off-topic. Either reword or remove it. \$\endgroup\$ Dec 8, 2015 at 16:25
  • \$\begingroup\$ Made an attempt to reword \$\endgroup\$
    – Mauvai
    Dec 8, 2015 at 16:39
The third wire (as in, the one which is not the + or - battery terminal wires) will be a built-in PTC (positive thermal coefficient) thermal resistor, or "thermistor". These are used in closed loop temperature monitoring by charge controllers. This battery has no balance charge leads. Most chargers will slowly and carefully inject current while monitoring temperature until the current drops off to a point (or after a timer) where it switches to voltage mode and leaks the last amount of charge into the cells. Without a balance lead to help the controller do the control or per-cell injection, it just has to assume the cells balanced themselves over time.
So the main point is, that extra wire is a thermistor which a charge controller can read to do temperature monitoring of the battery pack. This is critical because Li-Ion batteries are susceptible to overheating and exploding while charging so these thermal feedback mechanisms are important for safety, though not actually required of course.
