Desperately trying to find a receptacle to match these 10-years-old cords which come from a Beckman Coulter FC500 cytometer. Anyone know the name?
The receptacle previously used is labelled "AMP" with a squiggly M.
Requested infos: Diameter of connector barrel at the end is 4.2mm/.165". Length of gold cap portion is 15.5mm/.610"
The connector seems to be push insertion, with a cheap friction-lock style retention clip on the receptacle (easily bent).
I've included the bag labelled "FOA" but it's electrical, not fiber optic! Could just be a reused bag...
enter image description here enter image description here enter image description here enter image description here enter image description here
    \$\begingroup\$ Wtf. Never seen that thing before. But others may have. To assist them you could take a caliper and add some measures to your question. I.e. diameter and length for a start. \$\endgroup\$
    – Ariser
    Dec 8, 2015 at 20:44
  • \$\begingroup\$ Also some better pictures (including better cropping) won't hurt, my guess would be something custom though. \$\endgroup\$
    – PlasmaHH
    Dec 8, 2015 at 20:53
  • \$\begingroup\$ Added requested infos. Sorry my camera can't really focus on really small things that well. \$\endgroup\$
    – Keegan Jay
    Dec 8, 2015 at 21:08
  • \$\begingroup\$ The connector sockets are marked AMP. That's part of TE Connectivity. You might have some luck contacting them. \$\endgroup\$
    – Simon B
    Dec 8, 2015 at 22:23
More precisely the are called "Coaxicon" by TE; here's a brochure http://www.farnell.com/datasheets/595245.pdf. Beware that they come in several sizes. It looks like yours are the "miniature" version (there's also "subminiature" and "size 8"). Since it seems you want the PCB-mount socket (there's also a cable mount):
They are TE connectors, at digikey http://www.digikey.com/product-search/en?mpart=201145-4&vendor=17 typically used with backplane connectors, it seems.
  • \$\begingroup\$ +1 because Helpful, but OP is looking for the single pin plug/female receptacle. \$\endgroup\$
    – Passerby
    Dec 9, 2015 at 4:52
  • \$\begingroup\$ Thank you! This is just as helpful. Were you already familiar or did you search for it somehow? \$\endgroup\$
    – Keegan Jay
    Dec 9, 2015 at 11:44
  • \$\begingroup\$ I am somewhat familiar with this style of connector but I did an image search "te amp coax miniature" and found it \$\endgroup\$
    – johnnymopo
    Dec 9, 2015 at 16:14
