8
I've heard that there is effectively a minimum wire size for vibrating environments. In other words, when designing wires that will experience vibration (in my case, an automobile), it's recommended to make all wires 24 AWG or larger, regardless of the amount of current they'll pass.
Is there any wisdom on this? How can I decide if my wires are big enough to avoid shaking themselves apart?
    \$\begingroup\$ I don't know the answer. But I just want to clarify for any who may find this question via a search engine. For any wire, the finer the individual strands that make up the wire, the more resistant it will be to flex and vibration. It may seem counter-intuitive, but it is true. \$\endgroup\$
    – user57037
    Dec 8, 2015 at 21:37
  • \$\begingroup\$ ..and what if you are using transformers, coils and lamps with finer wires? Who is recommend this? The only exception may be applied at NiCr heating elements, and off course there is particular practices for harness. \$\endgroup\$
    – GR Tech
    Dec 8, 2015 at 23:49
6
Step one in vibrating environments is taking care of your wire ends, such as hinted at by Spehro.
If you solder or spread out the inner conductors they become effectively one or more individual wires with very limited strength and vibration resistance. This is why professionals crimp all their terminals and if really important use a ferrule around the cable and then crimp that. (A well chosen ferrule will keep the wires relatively well grouped, even when very forcefully crimped afterwards).
After that, you need to be worried about the outer sheath of your wires vibrating along a rough edge. Either you need to prevent that, by use of many support points, or you can harden the wire bundle against it with reinforcements.
Once you are at that point, you need to start considering wire size and stranding.
For automotive they may set a silly standard as "AWG24 and no less", but that is more probably because of the limited insights into the matter in some parts of the industry. (Easier to tell garage personnel to never buy less than AWG24, than to explain the finer points).
The more sensible rule, however is the one seen in Spehro's answer: No fewer than X or Y strands for N or M amount of vibration force. Of course many different kinds of definitions and specifications exist for minimum or maximum vibration force in any kind of system, so this may quickly get cloudy, again a reason to just say "AGW24".
To expand a bit on mkeith's comment: The thicker a copper rod (wire or otherwise) the more distortion a bending force will create in the material. The more distortion accumulates the quicker the metal will fatigue. If you have an infinitely small wire, it has infinitely little distortion at a sharp angle. In fact, chip bonding wire, which can be as small as several or dozens of micron, can sway in the wind bending and vibrating without snapping for a very long time.
So if you want very flexible and very long lasting wire, you're looking for a wire made up of as many tiny strands as you can find.
A usual thing is 0.06mm buildup of wire with a silicone or teflon sheath for extremely high flexibility and vibration resistance. As well as high temperature performance. But the same wire make-up exists in PVC or PP wire, or wire wound, or glassfiber reinforced silicone. With such tiny wires you get the 19 stands Spehro mentions already at AWG28, with the added luck that the thinner strands will give you an extra margin, as discussed above.
Be careful with Silicone or other soft plastics, though, as this is much, much easier to damage with small sharp edges. Many automotive solutions only allow soft plastics within safe areas, where the wires get wrapped in glassfiber reinforcement sheaths when they get routed along hard and sharp surfaces that may rub along them.
TL;DR (concluding):
If you have very thin strands, you can have thinner wires, because the metal fatigues much less the thinner the strand is. So if you have normal 7 strand wire at AWG24, that may well loose from 19+ strand AWG28 wire, vibration wise.
But before you start thinking about the thickness and stranding of a wire, you need to think about safely terminating the ends of your wire, in no case use solder joints to start and about damage to your wires caused by rubbing and cutting along hard edges.
The FAA's recommendation for aircraft may be applicable- wires less than AWG 20 should receive extra support (including terminations) and should not be subjected to 'excessive vibration', and wires with less than 19 strands should not be used.
Of course if the wires are adequately supported (for their length) there is no lower limit. The bonding wires inside a ceramic-packaged IC such as a MEMS accelerometer used in airbag controls would be something like AWG 50 and they survive just fine (because they are so short). Similarly, fine wires bundled together may be okay if care is taken with the terminations.
Determining vibration resistance is a bit complicated- if the vibration happens to have significant energy at a resonance and the mechanical system is poorly damped you can get a much larger motion than at slightly different frequencies.
