I am trying to find power in this circuit.
I have calculated this multiple ways and I keep getting the same answer
R Parallel = 3.846-j0.769Ohm
R total = 3.846+j2.23Ohm
I total = 7/(3.846+j2.23) = 1.36 - j0.7898Amp
P Source Avg = (((7)(1.36-j0.7898))/2)cos(-30) = 4.76Watt
Using node to find Va:
((1/j3)+.25+(1/(-j20)))Va - (7/(j3)) = 0
Va = 4.63-j4.086 Volts
Va/4 = 1.157-j1.021Amps = (1.543<-41 degree)Amps
Power 4Ohm Avg = (((1.543)(1.543)(4))/2)cos(-41) = 3.594 Watt
or using loop
(4+j3)I1 - 4I2 +7 = 0
And
(4-j20)I2 - 4I1 = 0
4(I2 - I1) = 1.158 - j1.021
This is the moment I realised I have the correct answer using loop already written down
I am still unsure what is wrong with my node approach
((1.573*7)/2)cos(149) = -4.7182 Watt
Power average supplied by the source is: 4.76w
Power through the resistor is: 3.594w
Now I am reasonably confident in my answer but it does not make sense. Because the average power through an inductor and a capacitor is 0 shouldn't the power from the source and the power absorbed by the resistor be the same amount?
  • \$\begingroup\$ Please edit your schematic and re-post the question. You have a DC power supply; '7<0degree' is not a voltage so we don't know what it means; you can't buy j3 H inductors or -j20 F capacitors. If you put in an AC power supply you should be able to simulate the circuit on CircuitLab. Show us your calculations. \$\endgroup\$
    – Transistor
    Commented Dec 8, 2015 at 23:13
The power delivered by the source should exactly match the power dissipated by the resistor but this is only true once the circuit has settled down.
From a transient point of view energy is shipped out from the source and that energy produces heat in the resistor but also "charges" the reactive components.
This means that initially more power is taken from the source but, after the transient has settled down, the power in the resistor IS the power delivered by the source.
You have made a mistake but, you haven't shown your workings.
