I'm using an LED that is rated at (0.06W) current is 20mA and voltage is at 3V. I did some wrong calculations, and the resistors I'm using are not enough to limit the current to the diodes.
The current is 0.024A now, can the LED work without blowing up? I'm maxing it with higher power would it manage?
    \$\begingroup\$ It won't blow up, but it may die young. I'd suggest 0.24A for "die a lot faster" and perhaps 24 amps (with plenty of volts to maintain an arc after internal parts expire) if you really want to have it "blow" nicely. ;^> \$\endgroup\$
    – Ecnerwal
    Commented Dec 10, 2015 at 2:53
  • \$\begingroup\$ There are part tolerances in your LED, resistor and meters, even small errors can shift the operating point of and LED in such a circuit. If the LED is never getting too hot to hold between your fingers it will likely live a long time (less than the rated but not much). Also note max current may already be more than operating current which you should be aiming for. \$\endgroup\$
    – KalleMP
    Commented Dec 10, 2015 at 8:46
4 Answers 4
Unless you are grossly overloading the device, it will not blow immediately. However, as with all devices too much heat will kill it eventually. If you can add a bit of heatsinking (usually not possible with common LEDs) then it will be fine, otherwise derate the MTBF of the device accordingly.
If the LED current is 24 mA, and the recommended maximum current is 20 mA, you can probably expect a somewhat reduced life for the LED, but it is unlikely to be destroyed instantly.
If the values you placed are correct \$ Vled=3V, R1=200\Omega, V1=4.8V \$ your actual current is:
\$ Iled=\frac{V1-Vled}{R1}=9mA \$
Therefore, no overload. Check your values and/or your circuit.
If you keep the junction within reasonable temperatures the LED will not die immediately but you will accelerate the aging process.
It seems your error is serendipetous and you're actually pushing less current through the LED than it's rated for. :)
If you don't exceed the LED's recommended forward current, it'll last for a long, long time.
To determine the value of the ballast resistor, you can do this:
$$ R1 = \frac {V1-VfLED}{IfLED} = \frac {4.8V - 3V}{0.02A} = 90 \text{ ohms} $$
