Is there a standard that gives the hole and pad size for soldering a wire to a PCB?
The IPC-7251 standard gives hole and land diameters for a given lead diameter. But because the finished hole diameter is 0.25 mm bigger than wire, these holes are difficult to get stranded wires into without them unraveling.
I cannot use a connector for this application.
