I'm new to this site. I have a small experiment. I did trying to make a circuit from a schema that needs 10uF Polarised Capacitor in the schema. I use Qucs (Quite Universal Circuit Simulator) qucs.sourceforge.net as the tool. But I couldn't find the Polarised Capacitor there. Does anyone know where is it ?, xD. Hehe sorry I barely learn about E-Engineering. Thanks before
1\$\begingroup\$ Just use a non-polarised one. In most cases it will make no difference at all to the simulation. \$\endgroup\$– Tom CarpenterDec 12, 2015 at 1:35
\$\begingroup\$ @TomCarpenter oh really ?, I'll try. Thanks tom \$\endgroup\$– Michael TanusenjayaDec 12, 2015 at 1:37
1 Answer
To transform the component symbol in a polarized capacitor, once you put it in the scheme:
you double-click to open the properties window.
There are three options: C to the value of capacitor, V for initial voltage and Symbol to select between neutral and polar.
The polar version:
Note: version 0.0.18 of Qucs
\$\begingroup\$ Surprising, I didn't know that. Nice answer!! Thanks Martin \$\endgroup\$ Dec 12, 2015 at 2:04
