i want to interface a gps module and an antenna. I found this kind of antenna (example) It does not mention its type.
Is this an active or a passive antenna? How to be able to know by myself without the need of asking here?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityi want to interface a gps module and an antenna. I found this kind of antenna (example) It does not mention its type.
The data sheet says: -
ORG9802 is a miniature antenna assembly, comprising four components:
- Ceramic patch antenna element
- Adaptor PCB
- Coaxial cable (option)
- Connector (option)
Everything above is passive
In answer to your "How is this possible" question: The RF signal and DC power are both on the center conductor of the cable. At the receiver the RF is blocked from the receiver's power input with a choke, and the DC power is blocked from the signal input with a capacitor.
