I want to make my own valve amplifier, and for that, I'll be using an 12AU7 dual triode tube. Since the 12AU7 is quite large, is there a sub-miniature version available?
Also: the main difference between the European ECC82 and the American 12AU7 is the heater voltage of either 6.3V or 12.6V. I heard they can be both wired to use both voltages, could someone please explain how?
There is no significant difference between the ECC82 and the 12AU7 - it's just different nomenclature for the different markets. As for the heater voltage, the two heaters can be connected in series (12.6 V @ 150 mA) or parallel (6.3V @ 300 mA). Parallel is more common since most mains transformers for valve designs have a 6.3V secondary winding. I have no idea whether a sub-miniature version is available.
There are probably subminiature tubes that will work, but submini's tend to have smaller maximum power dissipation and plate voltages. So you will likely need to re-engineer the circuit, or at least recalculate dissipation. I would suggest finding another medium-mu dual triode on ebay, look at the specs on http://pw1.netcom.com/~wa2ise/radios/penciltubes.html and see if it will work in your circuit. For example, the 6111 has low gain like the 12AU7, but dissipation and plate voltages are limited.
I would not suggest to anyone to use subminiature tubes instead of highly available 12AU7 or ECC82 if you prefer (or E82ECC). Besides this tube is very, very good in hi-fi assemblies and you should not low anode voltage way below 250V, although i made guitar amp with 12V on it's anode.
If you're not familiar with voltage higher then 100, I strongly suggest to use ECC88, very nice (maybe better) double triode which runs beautifully at 90V. And yes, this tube has different heater characteristics (only parallel heaters).
the 12AU7 and other 12A?7 derivatives can be run off a 12-Volt supply. try a google search on DIY headphone Hybrid amplifiers. in addition there are now Low voltage pencil tubes available out of the Former Soviet Union, some of these tubes have a maximum plate voltage of 30 volts, which are designed to be run off battery packs.
