I try to use UpMode timerA configuration on MSP to get PWM with arranged Duty Cyle. So here is my code below:
#include "msp432.h"
#include "driverlib.h"
void SetConfiguation(void);
int main(void)
    WDT_A_holdTimer();
    SetConfiguation();
    while(1);
    Interrupt_disableMaster();
    CS_setDCOCenteredFrequency(CS_DCO_FREQUENCY_24);
    CS_initClockSignal(CS_SMCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_128);
    /* TimerA UpMode Configuration Parameter */
    Timer_A_UpModeConfig upConfig =
            TIMER_A_CLOCKSOURCE_SMCLK,              // SMCLK Clock SOurce
            TIMER_A_CLOCKSOURCE_DIVIDER_64,          // SCLK/64 = 24MHz/128/64 = 2929 Hz
            24,                           // 50000 tick period
            TIMER_A_TAIE_INTERRUPT_ENABLE,         // Enable Timer interrupt
            TIMER_A_CCIE_CCR0_INTERRUPT_ENABLE ,    // Enable CCR0 interrupt
            //TIMER_A_CCIE_CCR0_INTERRUPT_DISABLE,     // Disable CCR0 interrupt
            TIMER_A_DO_CLEAR                      // Clear value
    P1DIR |= BIT0;
    P1OUT &= ~BIT0;
    Timer_A_configureUpMode(TIMER_A0_MODULE, &upConfig);
    Timer_A_CompareModeConfig compConfig =
        //uint_fast16_t compareRegister;
        TIMER_A_CAPTURECOMPARE_REGISTER_1,
        //uint_fast16_t compareInterruptEnable;
        TIMER_A_CAPTURECOMPARE_INTERRUPT_ENABLE,
        //uint_fast16_t compareOutputMode;
        //TIMER_A_OUTPUTMODE_SET_RESET,
        TIMER_A_OUTPUTMODE_TOGGLE_RESET,
        //uint_fast16_t compareValue;
        6
    Timer_A_initCompare(TIMER_A0_MODULE, &compConfig);
    //Timer_A_enableCaptureCompareInterrupt(TIMER_A0_MODULE, TIMER_A_CAPTURECOMPARE_REGISTER_0);
    Timer_A_enableCaptureCompareInterrupt(TIMER_A0_MODULE, TIMER_A_CAPTURECOMPARE_REGISTER_1);
    Interrupt_enableInterrupt(INT_TA0_0);
    PCM_setCoreVoltageLevel(PCM_VCORE0);
    PCM_setPowerState(PCM_AM_LDO_VCORE0);
    Timer_A_startCounter(TIMER_A0_MODULE, TIMER_A_UP_MODE);
    Interrupt_enableMaster();
void Port1IsrHandler(void)
void Timer_AIsrHandler(void)
    Timer_A_clearCaptureCompareInterrupt(TIMER_A0_MODULE, TIMER_A_CAPTURECOMPARE_REGISTER_0);
    Timer_A_clearCaptureCompareInterrupt(TIMER_A0_MODULE, TIMER_A_CAPTURECOMPARE_REGISTER_1);
    Timer_A_clearInterruptFlag(TIMER_A0_MODULE);
    P1OUT ^= 1;
In the Code, upMode works fine, interrupts work fine so I get 60 Hz what I want. But, to get PWM with arranged duty cycle, I need to use compare mode So I structed compConfig as seen on the code. However, it seems like there is no interrupt created for compare Mode. I use compare_register1 to catch interrupt but whether I put the compare interrupt enable or not result is same. It has no effect on the output. So, where am I doing wrong here? What is the correct way to achieve adjustable PWM.
Problem solved. I forgot to enable INT_TA0_N interrupt which includes CCR1 to CCR7 vector. In this case CCR1 determines the duty Cycle so I just added one more Interrupt to NVIC and enabled the interrupt. New code is like this:
#include "msp432.h"
int main(void)
    WDT_A_holdTimer();
    SetConfiguation();
    while(1);
    Timer_A_PWMConfig pwmConf =
        //uint_fast16_t clockSource;
        //uint_fast16_t clockSourceDivider;
        //uint_fast16_t timerPeriod;
        1600,
        //uint_fast16_t dutyCycle;
        200
    Timer_A_generatePWM(TIMER_A0_MODULE, &pwmConf);
    P1DIR |= BIT0;
    P1OUT &= ~BIT0;
    //Timer_A_configureUpMode(TIMER_A0_MODULE, &upConfig);
        //TIMER_A_OUTPUTMODE_TOGGLE_RESET,
        6
    //Timer_A_initCompare(TIMER_A0_MODULE, &compConfig);
    Interrupt_enableInterrupt(INT_TA0_N);
    //Timer_A_startCounter(TIMER_A0_MODULE, TIMER_A_UP_MODE);
    //Timer_A_clearCaptureCompareInterrupt(TIMER_A0_MODULE, TIMER_A_CAPTURECOMPARE_REGISTER_1);
    //Timer_A_clearInterruptFlag(TIMER_A0_MODULE);
    P1OUT ^= 1;
void Timer_A_N_IsrHandler(void)
    P1OUT ^= 1;
  • \$\begingroup\$ You could just omit the interrupt handlers, and use set/reset output mode to automatically toggle the output pin connected to the timer. \$\endgroup\$
    – CL.
    Commented Dec 16, 2015 at 13:51
  • \$\begingroup\$ what do you meanby "output pin connected to the timer" is there such thing? How do I assign a pinout to the timer? \$\endgroup\$
    – Alper91
    Commented Dec 16, 2015 at 18:19
  • \$\begingroup\$ Pins labelled TAx.y can be configured to output the timer's output. \$\endgroup\$
    – CL.
    Commented Dec 16, 2015 at 19:59
