I have a zero-cross solid state relay (Crydom CKRD2420) that regulates the power output of a 2kW@240V heater using 10Hz PWM (e.g. here to illustrate). I need the power output of the heater to be under ~2W when OFF. However I measured the leakage current is 25mA RMS (2.5 times the 10mA garanteed in the datasheet, by the way...), which means that the power leakage is about 13W (the mains supply voltage reads 264V).
My first thought was a current divider, but the bleed resistor would reduce by a factor of 10 the available power, and reduce significantly the efficiency. I can't use a normal relay because of the lifetime required (I need at least 50-100M cycles of operation), and power MOSFETs would be tricky to implement. Are there any simple-ish fixes I have overlooked?
