I'm designing a quartz component. I would like to use it with differents packages like those ones :
First Type at RS-Online
and
Second Type at Farnell
One of them has 2 pads, the other has the same 2 pads and 2 ground pads. I designed a schematic with 3 pads among them a power pad which is connected to GND and invisible.
This works pretty well for the 4 pads package but for the 2 pads package, when I compile, I get an error "Could not find port 'GND' on model 'QUARTZ_32x15' for pin 'GND'".
Obviously, that's right because there's not any ground pin on the 2 pads package.
So, is there a way to acheive this with something like saying that a pin may be optionnal or something like this? Or should I build one schematic for each package?
  • \$\begingroup\$ There are options to avoid it being a "breakable error", but personally I prefer making just two simple schematic components, because else you're opening the door to a lot of confusion and problems in the future \$\endgroup\$
    – Asmyldof
    Dec 16, 2015 at 15:01
Definitely build two schematic symbols in this case (just copy and modify one to add the two GND pins- I would definitely make both GND pins visible so you can see where they are connected on the schematic). They really are quite different components from a footprint point of view.
