In the 208/220v diagrams for 2 pole 3 wire outlets here(http://www.automationdirect.com/static/specs/wiringdevicesnemawiring.pdf) there have an arrow between the two wires that bring in 120v each and label the arrow 250 (or 208) volts. Are they just saying that there is 250v supplied total by these two legs, or that there is 250v between these legs?
I think it is saying that there is 250v supplied total, as I think there's 0v between the legs, unless the outlet is doing something like switching polarity?
Thus reason I am unsure is because the diagrams for 125v use the same arrow to show that there is a 125v difference between the hot wire and ground, so if they are not using the symbol in two different ways then the 250v diagram says that there is 250v between the two legs that have 125v each, which I don't see how that happens unless there is a built in Op amp or something...
Thanks.
