I'm building an FM radio transmitter kit which includes an LC tank, where C is a tuner capacitor of ~30pF and the resonant frequency is ~100Mhz. The value of the PCB trace inductor, however, is not specified and I want to know what it is.
If I plug:
\$100000000=\dfrac{1}{2π\sqrt{L3\times10^{-11})}}\$
into an equation solver the result is apparently 52771500 Henries. That seems... a little off? Considering most of the FM transmitter examples I've looked at on the net are like, 0.5uH?
How do I work this out?
    \$\begingroup\$ You seem to be doing a mathematical error. I'm getting \$ 84.43 nH \$ when I do the plugging in, which seems to be a reasonable number. \$\endgroup\$ – deadude Dec 17 '15 at 17:08
  • \$\begingroup\$ I don't know what I'm doing wrong then: screenshot \$\endgroup\$ – Ashlyn Black Dec 17 '15 at 17:14
  • \$\begingroup\$ Is the tuner capacitor the only capacitor in the LC tank or is there a fixed one in parallel? Please show the circuit diagramm. \$\endgroup\$ – Curd Dec 17 '15 at 17:18
  • \$\begingroup\$ @AshlynBlack: note how your link at the end claims that there is no solution. after their "switch sides" step they do crappy things to resolve that formula \$\endgroup\$ – PlasmaHH Dec 17 '15 at 17:25
  • \$\begingroup\$ Re: schematic (please don't sue me, Silicon Chip magazine) i.imgur.com/uyST5lQ.jpg \$\endgroup\$ – Ashlyn Black Dec 17 '15 at 17:31
I think this is a mathematical error as I specified in a comment. To clarify further, rearrange for L as follows.
$$ L = \frac{(1e8*2\pi)^{-2}}{3e-11} = \frac{1}{12\pi^2} \cdot \frac{1e-16}{1e-11} = 8.443e-8 H = 84.43 nH $$
The equation holds and seems to yield a reasonable value.
| improve this answer | |
Normally, the resonant frequency is calculated according to the following equation:
$$fr=\frac{1}{2\pi\sqrt{LC}}$$
Solving fo L you have
$$L=\frac{1}{4\pi^2Cfr^2}$$
Seting your values into it I found L= 84nH
