I'm trying to make a robotic drone from the body of an old quad copter, and I was wondering what these pins are enter image description hereenter image description here
  • \$\begingroup\$ Which pins? Are you referring to the white connectors? \$\endgroup\$ – Eugene Sh. Dec 18 '15 at 20:20
  • \$\begingroup\$ Can you measure the spacing between pins, is it 0.1 inch, 0.2 inch, 2mm? \$\endgroup\$ – MarkU Dec 18 '15 at 20:21
  • \$\begingroup\$ @EugeneSh. Yes, the white ones. \$\endgroup\$ – Enthurzan Dec 20 '15 at 19:05
Those are JST XH/PH connectors. XH if the pin spacing is 0.1", PH if the spacing is 2mm.
  • \$\begingroup\$ Seems to be like he space is 2mm. Thanks a lot! \$\endgroup\$ – Enthurzan Dec 18 '15 at 20:27
