I am trying to connect my apartment door bell system to my raspberry pi; I am not too good with the wiring, and hope someone can help.
What I have:
  • 3 wires from the door bell system: red wire, black wire, white wire.
  • 1 digital multimeter
  • 1 AC/DC to DC Power Supply Converter Step Down
The AC/DC to DC Power Supply has the following specs listed:
  • Input: DC 0V ~ 30V or AC 0V ~ 20V
  • Output: DC 1.25V ~ 28V (continuously adjustable)
  • Output current: 2A Max.
What I am trying to do: connect the wires from door bell system to the power supply, then output a 3.3v DC logic input to the raspberry pi.
What I need: the transformer needs a ground and a live wire, I need to find out from that three colored wires from the apt door bell system
what's my problem: my multimeter showed me some frustrated digits, I'm out of clues to define the correct wires, and here I am...
My multimeter result with the button not pushed:
black and red: 10v AC;
white and red: 12v AC;
black and white: 1.5v AC;
If I press the door bell button outside
black and red = 0v AC;
white and red = 12v AC;
white and black = 0v AC;
So how do I connect wires to the power supply?
  • \$\begingroup\$ the transformer is designed for 2v-30v AC to 2v-28v DC \$\endgroup\$ – Joe Lu Dec 19 '15 at 4:22
  • \$\begingroup\$ there's no such thing as an AC to DC transformer. \$\endgroup\$ – jp314 Dec 19 '15 at 4:31
  • \$\begingroup\$ don't know if i'm allowed, this is what i've brought, now my quest is to find proper wire to connect to this unit as AC input.. amazon.com/gp/product/… \$\endgroup\$ – Joe Lu Dec 19 '15 at 4:46
  • \$\begingroup\$ hi Ecnerwal, yes, I'm trying to get a logic input when the button is pushed, the rasPi is powered from its usb port, not from the door bell wiring \$\endgroup\$ – Joe Lu Dec 19 '15 at 5:03
Seems like a standard doorbell, though your "pressed button" status seems like a probable measurement error.
For detecting the doorbell button, connect to black and white - if that does not work, connect to black and red. The reason I'm pretty sure you have a measurement error is that if black and red are 0V and red and white are 12V, black and white should be 12V, not 0V.
Or, if black and white are 0V, and white and red are 12V then black and red should be 12V - Same circuit as above, swap labels for white and red.
So one of your measurements is probably not what you've said.
| improve this answer | |
  • \$\begingroup\$ thank you so much Ecnerwal, I will double check the measurement tomorrow again, and come back with you for the confirm figures. my apt is a very old one, I moved in last month and found out the door bell (or should be called intercom) was removed, all I found were three wires staying on the wall. The measurements sounds incorrect and that is exactly why I'm asking for help here. oh yes, I will stop using my figure, thank you again, lol \$\endgroup\$ – Joe Lu Dec 19 '15 at 5:26
  • \$\begingroup\$ Hi Ecnerwal, after spenting 2 days researching and trying, finally I figured out the odd behavior of these wires, in fact, they may all be live wires, connect white+red to form a circuit to open the door, the black itself as the logic of the push button. anyway, thank you so much for helping, wish you have a wonderful holiday. so i just need to wire the black one to the transformer, and maybe add a ground wire manually.. will try it later. \$\endgroup\$ – Joe Lu Dec 20 '15 at 18:23
