Hello guys I am trying to translate following VHDL code to Verilog, however it does not work even if they look like pretty same. I get no errors however it is not working with Verilog one but works with VHDL one. Can you guys please help me to work out this problem?
VHDL Code (working)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity binbcd8 is
port(
b: in unsigned(7 downto 0);
p: out unsigned(9 downto 0)
end binbcd8;
architecture Behavioral of binbcd8 is
begin
bcd1: process(b)
variable z: unsigned(17 downto 0);
begin
for i in 0 to 17 loop
z(i):='0';
end loop;
z(10 downto 3):=b;
for i in 0 to 4 loop
if z(11 downto 8)>4 then
z(11 downto 8):=z(11 downto 8)+3;
end if;
if z(15 downto 12)>4 then
z(15 downto 12):=z(15 downto 12)+3;
end if;
z(17 downto 1):=z(16 downto 0);
end loop;
p<=z(17 downto 8);
end process;
end Behavioral;
Verilog code (not working):
module binbcd8(input[7:0] b,output reg[9:0] p);
reg[17:0] z;
integer i;
always@(b)
begin
z <=17'b0;
z[10:3] <=b;
for(i=0;i<4;i=i+1) begin
if(z[11:8]>4)
z[11:8]<=z[11:8]+3;
else
z<=z;
if(z[15:12]>4)
z[15:12]<=z[15:12]+3;
else
z<=z;
z[17:1]<=z[16:0];
end
p<=z[17:8];
end
endmodule
It does not work. Can you please help me?:
std_logic_unsigned
library. Thenumeric_std
one should be adequate and avoids possible ambiguity. Also, the firstfor
loop is unnecessary :z := (others => '0');
replaces it with a single statement. \$\endgroup\$ – Brian Drummond Dec 19 '15 at 16:46
