Has anyone been able to get a PICAXE working with the BlinkM? What is the I2C speed?
Do you mean standard i2c speeds or something specific to picaxes or blinkM?
"The standard clock (SCL) speed for I2C up to 100KHz. Philips do define faster speeds: Fast mode, which is up to 400KHz and High Speed mode which is up to 3.4MHz."
quoted from http://www.robot-electronics.co.uk/htm/using_the_i2c_bus.htm
EDIT: Found this: http://getsatisfaction.com/thingm/topics/picaxe_communication which should give you at least something to test your setup with.
This was useful:
