I work in the power distribution industry and recently came across a 3-phase LV circuit with "twin-wired neutral" (i.e. two neutral cables inter-winded, therefore five cables total). What would be the point of such a neutral configuration? Would this be to carry more current due to neutral currents/unbalanced phases?
Cheers!
    \$\begingroup\$ Could you clarify what you mean? Possibly a diagram? I am certainly no expert, but I am unsure what you mean by twin wire neutral? Was it just two wires connected to the same nodes? \$\endgroup\$
    – Matt Clark
    Dec 21, 2015 at 5:13
I think you are right, probably is to handle more current due to unbalance. Neutral cable's section for distribution transformer, should be the same as the phase conductor.
