Today I find my lenovo laptop power adapter's output negative terminal is not grounded (the input ground terminal is not connected with output negative terminal, measured with DMM). But another old one is just opposite, the output grounded. Why? There is any standard for power adapter? If the laptop is not grounded, is it safe?
My experience is that the power supplies for the older laptops in which the backlight was CCFL were usually grounded on the DC side as well. I suspect it was because of the high-voltage inverter needed for the CCFL (approx. 600V DC output), but I'm not entirely certain that was the determining factor. There's a concrete example of an older HP I have that does have minus grounded; details on that in this superuser post.
The newer laptops with LED backlight tend not to have the minus pin grounded. There can be static buildup and leakage currents on the non-grounded laptops [the latter particularly on metal cases] which can be irritating to some people. See this discussion on MacBook and this video of an actual measurement; he only measured AC voltage from case to ground as 78V AC with no grounding, which is probably enough to feel a slight tingle on a leakage current. A better test would have been to measure the leakage current as well... but I guess you need to try harder finding EE pros among Mac fans.
  • \$\begingroup\$ Note that in the US there's a very confusing terminology promoted by the NEC in which the neutral is "grounded" and the earth is "grounding"; above I just mean earthed by either term. No laptop power supply is going to connect DC minus to the neutral because the phase and neutral can be swapped easily with some plug styles. \$\endgroup\$ Dec 21, 2015 at 14:00
  • \$\begingroup\$ Yes, my two laptops both have 3 pins input plugs, so I don't mean the the neutral pin. \$\endgroup\$
    – diverger
    Dec 21, 2015 at 14:44
Some laptop adapters don't have an earth pin and therefore they can never have a grounded output. It's not a problem providing that the insulation and clearance/creepage distances inside the adapter are adequate.
If a laptop uses a grounded adapter and the adapter is unplugged from the laptop then, the laptop isn't grounded - it's clearly safe in this scenario and, just as safe as when plugged into a properly designed and manufactured adapter that doesn't need an earth pin in the AC plug.
  • \$\begingroup\$ I find some of them the input ground connected with the output negative terminal, but some not. Are there any standard for this? Which is better? It's weird the input has a ground pin, but the output negative is not connected with it. \$\endgroup\$
    – diverger
    Dec 21, 2015 at 11:28
  • \$\begingroup\$ That said, when used in lab environments and/or with (other) grounded peripherals, it may be marginally better to have one that is physically grounded to reduce or eliminate common mode fiddlyfoops (tm). \$\endgroup\$
    – Asmyldof
    Dec 21, 2015 at 11:44
  • \$\begingroup\$ @diverger In the EU I don't believe there is a specific standard other than meeting the low voltage directive and EMC directive but this applies (as a minimum) to any electrical goods plugged into a wall socket. \$\endgroup\$
    Dec 21, 2015 at 12:01
The first thing to understand here is that the AC ground coming from the wall, does not serve the same purpose as the DC ground going to the laptop.
They both typically sit at 0V and are often physically connected, but they serve different purposes. The DC ground is used to complete the circuit so power can flow, the AC ground is used for saftey, the power flows between live and natural and, under most circumstances, won't touch ground at all.
The AC ground is used when there is a fault. For example, say the live wire came loose and touched the casing of a metal microwave. If anyone touched the microwave, the AC power would flow through them and most likely kill them. To prevent this the casing is connected to the ground wire, so as soon as the live wire touches the casing, a massive current flows through the ground, which blows the fuse / trips the breaker, isolating the device.
This ground connection is not necessarily needed if the device is suitably insulated. Phone chargers often don't have a ground pin (or for me in the UK, they have a plastic one) because if a wire did come loose, there is very minimal chance of shock as the whole device is insulated.
In your example of the laptop charger, the AC side of the charger often has a ground pin. I'm not sure if this is required or if some manufacturers are just being extra careful. However the DC side of the charger does not require one, as it is insulated very well from the AC connection, if the live wire came loose inside the charger, there is no way it could make your whole laptop live, so there is no need to ground your laptop.
Some times the manufacturers simply ground the whole ground plane within the charger, which the negative terminal of the charger is connected too. This is why sometimes you see a connection, and sometimes you don't, it's not needed at all, it just happens sometimes due to every 0V being connected together.
    \$\begingroup\$ The AC ground isn't just there for faults - it's also a vital connection for the reduction of EMI. Also, on a lot of older designs the AC ground IS the same as DC ground i.e. it IS connected. Maybe you are a little behind the times on UK legislation - the use of RCDs now largely protects against severe shock in households. Earthing of metallic objects containing mains wiring is required if not using reinforced insulation and that is maybe what you refer to? \$\endgroup\$
    Dec 21, 2015 at 12:06
  • \$\begingroup\$ Ah, thank you, completely forgot about EMI. I guess I wasn't quite clear enough the with the difference between AC and DC ground, I meant that they perform different functions, I.e. cutting the AC ground won't turn the device off, but cutting the DC ground will. \$\endgroup\$ Dec 21, 2015 at 12:16
