I am trying to analyze the operation of a BJT H-bridge configuration. I have searched through these forums and Google and can't seem to find an answer to my question.
It is my understanding that it would be desirable to have the "ON" transistors in the saturated state, to provide maximum supply voltage to the motor. This is also a general practice whenever using BJTs as switches. They should operate at cutoff and saturation.
I tried to simulate a simpler circuit, ignoring the two "OFF" transistors and only looked at the two "ON" transistors. Suppose I wanted to have my bridge supply 1 amp of current with a 5 volt supply (arbitrarily chosen). I used a 5 ohm resistor as the load to simulate the motor. If both transistors saturate (Vce <= 0.2 V), then the load should receive about 4.6 V. In simulation the load receives only about 1 or 2 volts.
Schematic
If I lower the base resistances to increase base currents, it improves to about a maximum on 2.8 V across the load. If I increase the load resistance to about 50 ohms, then I can get about 4.7 V across the load, but obviously the current is not what I want.
I've read for saturation that Vbc should be forward biased, or Vb > Vc. This explains why increasing the load resistance causes the bridge to go into saturation, since the voltage drop across the resistor gets large enough for Vc to become less than Vb. Though, with such a small load resistor it takes a lot of current to make an appreciable voltage drop. If beta is a worst case of 50, then an Ib of 20 mA should be enough to provide 1 A at the collector. However, even when I make the base resistance ridiculously low (10 ohms), I still do not get anywhere near supply voltage across the load.
Does this mean that it is not possible to saturate the transistors with such a small load resistor?
  • \$\begingroup\$ Are your transistors really 2N3904 and 2N3906 or are you just using those because apparently that's all that comes with multisim (which based on graphics is what you seem to using as simulator)? \$\endgroup\$
    – Fizz
    Dec 22, 2015 at 14:52
There are some point to keep in mid when asking a question like this. First there's no guarantee that transistor model that shipped with simulator X matches the datasheet from manufacturer Y, even for the same generic transistor type. If you need to operate in heavy saturation (hfe=10) then you can probably get by with using almost any model. If you want to operate in quasi-saturation (Vb>=Vc but hfe doesn't get close to 10) then you need to be careful what SPICE model you use.
Second, 2N3904 or 2N3906 are only good at most 200mA Ic in real life. So don't expect any SPICE model for them to be terribly useful at 1A. Usually some software like MODPEX [or similar] is used to generate the SPICE model by curve fitting from the traced curves; the derived parameters aren't necessarily much good beyond the window in which they were derived because the Gummel equation uses some parameters that pretty difficult to determine accurately. Here are the Gummel plots of two 2N3904 models I happen to have done already; first is the one that comes with LTspice (supposedly from NXP, but God knows where they pulled that data from) and second is the one actually downloaded by me from NXP.
LTspice 3904 actual NXP 3904
There's a big difference between them in terms of how hfe varies and even what the max value is (in the active region) or how low it drops in saturation (Vbc was set to 0 in these plots). So before anyone can answer your question with more than a handwave we need to see the SPICE models that your sim uses for those transistors.
To get more to the point of your question, since you apparently using multisim (not exactly my favorite; I find the "virtual instruments" paradigm of having to modify the schematic to measure stuff on it incredibly clunky by design), I just imported their [NatSemi] 2N3904 model in LTspice. Basically you cannot saturate it at 1A collector current (for any base resistor), as you can see from the following sweeps:
The green curve is the power dissipation over the transistor. You can see that at 25 ohms load (corresponding to 200mA Ic, max allowed in datasheet), there's a pretty wide region for choosing the base resistor so that the transistor is in saturation. This margin gets smaller as we lower the load resistor. At 5 ohms load (top curve), you basically have nothing left; even with the optimal/minimum value it would dissipate nearly 1W. Never mind that it would burn the transistor in real life by exceeding the collector current alone. I'm not entirely sure what explains the massive difference we see with this model between 10-ohm and 5-ohm load, but it's probably caused by a combination of high-level injection dominating [Ikf, the forward knee current is 66mA] and the built-in collector package resistor (this is 1 ohm); the emitter resistor is not set in this model. If we set the load to 5 ohms but alter the built-in collector resistor to 0 we can see it would saturate to a more reasonable power dissipation level--the lower curve below:
  • \$\begingroup\$ You might also find my answer to somewhat similar question useful for background on quasi-saturation etc.: electronics.stackexchange.com/questions/198125/… \$\endgroup\$
    – Fizz
    Dec 22, 2015 at 14:16
  • \$\begingroup\$ Thanks for the detailed answer. I see why it cannot saturate. My Multisim SPICE model is identical to yours in LTSpice (Bf, Ikf, Rc, etc..) I did not think that simulation took into account max current, but I can see that elements of the SPICE model will create large voltage drops and limit currents indirectly, without directly setting a max "smoke" current. By trying a different pair of power transistors: 2N6490/2N6487 (Ikf = 3.8 A, Re = 0.0004 ohms, Rc = 0.096 ohms), my results were much better. With Rb = 220 ohms, I can get 4.73 V at the load. With Rb = 43 ohms, there is 4.82 V at the load. \$\endgroup\$
    – Pansy
    Dec 26, 2015 at 17:41
To answer your question directly, You have both of your transistors in saturation mode. That is not the problem. A quick look at the data sheet from ON Semi's 2N3906 states that the MAX collector current a 2N3906 can sustain is 200mA (same with 2N3904). You will never reach 1A. Please select another BJT pair.
  • \$\begingroup\$ Thanks Dave, I know those transistors cannot sustain that current. I just didn't think the simulation took into account maximum current. The pair of power transistors 2N6490/2N6487 worked better for me, see my comment to Respawned Fluff. \$\endgroup\$
    – Pansy
    Dec 26, 2015 at 17:47
You are not saturating these transistors.
The common definition of Hfe at saturation is Hfe=10.
Looking at either of your transistors, the base current is about 4.3mA and the collector current is about 250mA so you are operating the transistor at Hfe=60 (approx), so it will stay well out of saturation. As it happens the specific transistor model you use reaches this point (Hfe=60) at about Vce=2V, Ic=0.25A.
As you want about 1A (5V across 5 ohms) you want to arrange for Ib approximately 0.1A, so set R2=R4=43 ohms and try again.
Can 2N3904/06 handle 1A safely? If not, you need to both upgrade them and increase the base current.
If you are driving the H bridge from logic outputs, these cannot supply 0.1A easily, so you'll probably need a second stage (e.g. simple emitter follower) as buffer for each base driver.
  • \$\begingroup\$ That alone won't work because it turns out the 2N3904 model he's using has a package collector resistor of 1 ohm, which becomes significant at the load level he's trying to [ab]use it at. All this is a rather academic exercise anyway [with respect to real-life 3904], but good for learning about the SPICE BJT model... \$\endgroup\$
    – Fizz
    Dec 22, 2015 at 17:50
  • \$\begingroup\$ Thanks Brian, Yes, my base resistance shown on the schematic was too high, but I mentioned in the text that I lowered it as low as 10 ohms and still did not obtain anywhere near 4.6 V. I know the 2N3904 cannot handle 1 amp of current, I did not think that simulations took the max current into account. It is just one of the most common transistors, so I used it as a thought exercise. I guess in hindsight an "ideal" transistor with a much simpler model would have been more suited to this. \$\endgroup\$
    – Pansy
    Dec 26, 2015 at 17:24
