I have a project for my university on the transfer function (where a,b,c are constants):
$$G(s)=\frac{(s+a)}{(s^2+bs+c)}$$
and I'm asking how to represent this whole thing with an OPAmp circuit.
(The difficult part that got me the most time thinking, is the numerator) I would like some help in order to implement it myself and not an immediate solution.
  • \$\begingroup\$ Your transfer function has one zero and two poles. There's many ways to implement this using op-amps. One thing to consider is that the best implementation might depend on whether the poles are real or complex. \$\endgroup\$ – The Photon Dec 22 '15 at 5:34
  • \$\begingroup\$ Look at 'controller canonic' form of a TF. This method has no restriction on real/complex poles. \$\endgroup\$ – Chu Dec 22 '15 at 9:47
  • \$\begingroup\$ Are you expected to vary a, b and c independently and demonstrate what happens or are you looking for any op-amp solution that is if the general form of your equation. Think about this because one option is really tricky. \$\endgroup\$ – Andy aka Dec 22 '15 at 9:53
  • \$\begingroup\$ i have specific values for a,b,c ... poles are complex. I just wanted some general help so i didn't fit in the values. \$\endgroup\$ – lefkadios Dec 22 '15 at 20:34
since this is 2nd-order, consider the Sallen-Key circuit and add to it another op-amp circuit that sums (with weighting factors) the voltages at \$V_\text{OUT}\$ and \$V_\text{x}\$. (reference to Figure 1.)
|improve this answer|||||
