I am going to be soldering in an enclosed space, so I am building a fume extractor via ducts. My eventual plan is to have one fan near the vent, and another somewhere near the inlet to help the fumes get to the ducts. So my question is how powerful should the first fan be, preferably in CFM, and if I need the second fan. Thanks in advance.
It depends on how much area you want to cover. I generally see under-bench systems with vent hoses in the range of 150-200CFM. The desk top ones can have lower flow rates as they usually sit closer to the work, where as the under bench systems draw more air as they're meant to have the vents sit further away. Keep in mind depending on how aggressive your filter is you may need to get a stronger fan to deal with the resistance presented by your filter.
If you want an idea as to what commercially available units use for a sense of scale, look at vendor sites. They usually specify the flow rates for their products. Some suggestions to get you started would be PACE, and Hakko.
You should only need one fan.
  • \$\begingroup\$ Thank you! I will up vote as soon as I get enough experience \$\endgroup\$ – Reid Sox-Harris Dec 22 '15 at 17:20
  • \$\begingroup\$ Happy to help! Good luck. \$\endgroup\$ – alphasierra Dec 22 '15 at 21:39
